12-05-2002, 03:47 PM | #1 |
Senior Moment
Gear reduction starters
Anybody use a gear reduction starter? I saw them at the local Chevy dealer and was wondering if they are worth the extra $$
I was concidering one for the BB when I get it done.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
12-05-2002, 06:44 PM | #2 |
Senior Moment
anybody????
12-05-2002, 06:46 PM | #3 |
Post Whore
Blazerboy was discussing these with me and Barn9 a few weeks ago. He is a GM mechanic and had great things to say about them. I believe he is using one on his big block.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-05-2002, 06:48 PM | #4 |
Senior Moment
Thanks Yukon, has that 54 made any smoke yet?
12-05-2002, 07:23 PM | #5 |
Resident Young Old Dude !
http://www.4alterstart.com/pages/sto...m/racestarters
STEVE, I don't know if I did that Drag and DROP stuff right or not, I've never done it before. But this is a site for a RACE starter that is built for S.B. and B.B. putting out some horses with compression. I don't have one yet, But the key word being YET... RON |
12-05-2002, 07:45 PM | #6 |
Currently Blazerless
Try ebay under [mini starters], I got my ac delco with a year guarantee for 99.00 ,these starters use a shorter bolt so it's best to get the bolts for a few extra bucks, I can remove and install this starter with out loosining a header. This is the starter that comes with the 502 crate motor, has plenty of torque to spin my 383.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
12-05-2002, 09:09 PM | #7 |
I have one, although diff than pictured above.
Mine is similar to ones used on toyotas. It works great. 5yrs on it, and been installed on 2 motors, hasn't missed a beat. Worth the $$ IMO.
Jeff Scott '70 GMC Stepside, Short box '63 Nova '92 GMC typhoon '95 Tahoe |
12-05-2002, 09:18 PM | #8 |
The gear reduction starters work pretty darn well. Here is a shot of one together and one not... Uses a planetary gear system. A plastic planet and three metal sun gears attach to the shaft. Can be found on most 5.7 SBC after 96 and is available for 153 and 168 tooth. Also I have used CVR Nippondenso starter motored mini-starters with great success.
Here are the 4 variants. One on the right is same as one of the others but 153 tooth. Offset pattern is all 168. The smallert one, (2nd from right) is from a 4 cylinder. These are all painted black because they are out of boats. The gear ration is different in the "little" starter as well.
