12-06-2002, 10:54 AM | #1 |
Rear End Grease
WHAT WEIGHT AND TYPE GREASE SHOULD I USE IN MY 71 C10 POSI REAR END?
12-06-2002, 10:57 AM | #2 |
Go to GM they sell the lube you need you also need to buy a posi additive put that in first so that there is enough room for it then top up the rearend .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
12-06-2002, 11:00 AM | #3 |
Almost Satisfied
Do you mean oil? I just put a Eaton 3.73 posi in my 12 bolt and it recommended 80-90 weight gear oil. It actually said not to use synthetic oils. As for the posi unit itself Randys Ring and Pinion sent me some posi oil in a little bottle. The guy that set mine up recommended the Mystick JT7...in fact he said that is all he would run......
Hope this is what you were looking for.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
12-06-2002, 11:05 AM | #4 |
THANKS GUYS!
