Old 01-26-2009, 07:42 PM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
headlights low beam only?
ok, yeah I ve been out of work way too long, but back to my question, I bought a set of new headlamps to put in my 72, did I buy low beam only?, is there a way to tell , I threw the boxs away months ago, if the are only a single beam and not low high beam.........
sorry I just dont know, because I bought a new dimmer switch and I cant see a change from high to low
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 01-26-2009, 07:58 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: headlights low beam only?
Are they interchangeable with the GMC's?
I looked at my GMC high beam. You can see it if you shine a light into the glass and at a certain angle you can see the filament. It has a single filament. My low beams are halogen and I don't know what the difference is, but it still only has one halogen lamp.
I would think if it was a hi/low light, it should have two filaments.
68gmsee is offline   Reply With Quote
Old 01-26-2009, 08:05 PM   #3
cparman
sharp as a marble
a high/low beam will have 3 prongs to connect the wiring to. A high beam only will only have 2. The dimmer switches can be fussy on our trucks?
cparman is offline   Reply With Quote
Old 01-26-2009, 08:54 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
is this a chevy or a GMC?
If it is a chevy, then you can only get hi/low lamps.
Plus, in reality, if you had the wrong lamp, the lights would turn off when you hit the other setting (hi or low) and then you'd probably notice it.
