Old 02-06-2009, 09:54 AM   #1
Tony_SS
Tony_SS's Avatar
Exclamation Doing a project today - Need some advice ASAP
I'm installing my stereo and carpet today - finally! And I have a sub box and an amp. I was going to install the amp on a piece of mdf, but what's the best way to secure the board to the back of the cab? I really don't want to drill into and have screws coming out the other side... any ideas?
TIA
Tony_SS is offline   Reply With Quote
Old 02-06-2009, 10:03 AM   #2
OrangeAnimal
OrangeAnimal's Avatar
Re: Doing a project today - Need some advice ASAP
Most people build a box with a flat area on it to mount the amp. I will see if I can find a pic.
OrangeAnimal is offline   Reply With Quote
Old 02-06-2009, 10:07 AM   #3
OrangeAnimal
Check this box out. You can enlarge the picture on the page to see it up close.
Also you could mount the amp under the seat. I have done it before using some flat steel bar attaching to the seat mounting rails and then attaching the amp to that. Good luck and post a pic when you are done!
Old 02-06-2009, 10:48 AM   #4
Tony_SS
Tony_SS's Avatar
The pic doesn't show? I really want the amp behind the seat next to the sub. The sub does have a flat spot to mount on the bottom but it still needs to be secured to the back cab wall to... somehow?
Old 02-06-2009, 12:14 PM   #5
OrangeAnimal
http://www.hifisoundconnection.com/S...id/0/SFV/30046
There is a link sorry about that.
Old 02-06-2009, 12:52 PM   #6
hobsiscool
you could use L brackets and mount it to the floor
hobsiscool is offline   Reply With Quote
Old 02-06-2009, 02:00 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
Velcro to the back of the cab ?
Mine's going under the seat. There really is a lot of room under there, even for a large amp. I was gonna velcro it so I can pull it out to adjust the gain and crossover.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-06-2009, 03:28 PM   #8
Moostifer
a fool with no money
Moostifer's Avatar
I've used silicone caulking before for the back attachment, worked very well, couldn't pull it off without a LOT of force, never rattled, and did'nt have to drill any holes.
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 02-06-2009, 10:25 PM   #9
OrangeAnimal
Yeah there is this construction adhesive made by loctite called power grab. U can glue anything to anything and it will hold. only thing is you might never get it off.
