Old 03-19-2009, 09:16 AM   #1
sgaylord
Project collector
sgaylord's Avatar
Wiring a R-4 A/C compressor
I put a serpentine system off a 89 Chevy truck on my 69 CST-10. I am having difficulty trying to figure out how to wire the compressor. My 69 has factory air with only 1 green wire for the old A-6 compressor but the R-4 has 3 wires. 1 green (I assume this is where I would connect the green wire that previously connected to the old a-6 compressor), 1 black (I assume this is ground) green and black are connected on the front of the compressor, and 1 tan on the rear of the compressor (I have no idea where this one (tan)connects) . I know others have installed these before but I could not find anything in my searches for r-4 a/c compressor wiring, r-4 compressor wiring, etc. Can someone help me figure out how to wire this thing? I have included some pictures to show what I am talking about.
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel
Jezebel 3.0 NEW!!!
2020 GMC 3500 Denali Duramax
2016 Harley Street Glide CVO
Roll Tide!
sgaylord is offline   Reply With Quote
Old 03-19-2009, 11:52 AM   #2
spinning wheels
spinning wheels's Avatar
Re: Wiring a R-4 A/C compressor
I would just check the wiring on an '89 truck with that compressor.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-19-2009, 03:04 PM   #3
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
The green one does connect to your old green one.
The black one is a ground. I think the original setup had the black one grounding right to the compressor mount somewhere close. Your new setup will work fine if you do the same thing. Be sure you retain the diode across the green and black wires.
The switch on the back with the tan wire is a high side cutout. It's supposed to kill power to the compressor clutch in case the system pressure goes too high. The original A6 system did not have this feature, and the new R4 will come on and work fine without hooking it up. If you're using the original POA setup you might be able to get away with not hooking up the high side cutout.
However, if you're sort of "manufacturing" a new system, like installing one of those POA eliminators, or converting to a CCOT system, I'd hook up the high side cutout just to be on the safe side. Hunt up a wiring diagram for the '89 truck to see how it was wired.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 03-19-2009, 03:15 PM   #4
sgaylord
Project collector
sgaylord's Avatar
Thanks lugnut64052 , I am using the stock POV setup with the pressure mod from 29 to 26 psi. Everything else is stock. Sounds like I should be ok then.
Thanks,
Steve
Jezebel 3.0 NEW!!!
Roll Tide!
Old 03-19-2009, 04:19 PM   #5
Lugnut64052
Excellent. You should be good to go without using the high side cutout.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 03-20-2009, 09:54 AM   #6
Chevy4Life
Chevy4Life's Avatar
I'm in the process of doing the same conversion. I'm using a 91 serp. setup and it doesn't have the pressure switch on it. It's good to know both style r-4s can be used. Could you tell me more about your setup? Are you using the stock condenser? Where did you get the fittings and hose made? Can you take some pics of the evaporator and condenser hookups? I'd really like to hear how well it works. Post some vent temps if you can.
Thanks,
Jay
Chevy4Life is offline   Reply With Quote
