Old 03-19-2009, 02:54 PM   #1
gmwoody
gmwoody's Avatar
pics of little lift bigger tires...
i want to see some people that take COG seriosly. i have been searching through the 4x4 pix section and i find one every few pages and no info.
could you guys post pics of your normaly lifted trucks with bigger 33 and up tires. i'm thinking of 37s and 4inch lift, moving the front diff forward and massaging the fenders. any other guys see my line of thought???
gmwoody is offline   Reply With Quote
Old 03-19-2009, 04:09 PM   #2
onlyifihadachevy
Re: pics of little lift bigger tires...
im not sure by what u mean massaging the fenders but 37s and a 4in lift with a the diff moved forward im not sure would work. It would still rub the back with just a little flex.
what kind of truck do u have?
if u do it post the pics.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 03-19-2009, 04:15 PM   #3
onlyifihadachevy
http://yotatech.com/f115/85-4runner-...n-37-s-157096/
you might be able it has no lift so i guess i was wrong but thats cutting a lot
My 72 thread
Old 03-19-2009, 06:20 PM   #4
gmwoody
gmwoody's Avatar
i have a '70 3/4 ton CST that i am planning on going 4" and 37 hummer tires. i saw a good thread on this site where one of the members cut a wedge out of each side of the fender behind the lip and welded the pieces back. really engenious i think and still looked factory. planning on doing that and more.
planning on moving the front forward 1.5" with the zero rate relocators and cutting and welding the fenders. i'll try and attach a pic of my stock truck now on 33s.
Old 03-19-2009, 06:43 PM   #5
gmwoody
gmwoody's Avatar
like these, i like the pirate post you put of the 4 runner.
maybe not as extreme as the ramcharger but the same concept.
Old 03-19-2009, 09:23 PM   #6
onlyifihadachevy
Hey you pirated from the samething but that dodge has 54in tires because those are the military tires and can he even turn or flex a little without rubbing
My 72 thread
Old 03-20-2009, 01:23 PM   #7
gmwoody
gmwoody's Avatar
Sorry if that was confusing, there was a "build post" on Pirate 4x4 about the 4 runner that i liked.
i will definetly be posting pics when i do mine.
Old 03-20-2009, 01:56 PM   #8
gmwoody
gmwoody's Avatar
found the pics front this site posted by Florida4x4.
just what i'm talking about.
running 42" tires and minimal lift. i think 6 inches???
Old 03-21-2009, 07:17 AM   #9
vtblazer
vtblazer's Avatar
The original lines of the fenders are changed a lot in those pics, looks like a
Ram Charger fender now.
What does 'COG' mean?
Here's another way of doing it keeping the factory arch intact.
vtblazer is offline   Reply With Quote
Old 03-22-2009, 09:17 AM   #10
I`m tappin`my noggin and gettin`no coggin`.So...uh...what`s COG and do I take it seriously?
Old 03-22-2009, 12:46 PM   #11
b454rat
Center of Gravity...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 03-22-2009, 02:10 PM   #12
onlyifihadachevy
What did you do to your blazer, what part did you cut?
just the front and move the axle forward? Because it looks very good, and i want to do something similar to my truck.
My 72 thread
Old 03-22-2009, 02:22 PM   #13
vtblazer
vtblazer's Avatar
Used two fenders.
Cut out the wheel well out of the 1st, cut out the wheel well out of the 2nd, spliced pieces into the lip to enlarge it yet keep it the same shape as the factory did.
This was an experimentle fender, never made a finished set.
Front axle is moved forward.
Old 03-22-2009, 09:23 PM   #14
stenbrin
stenbrin's Avatar
this is my k5 with 4 inch lift and 38-14.50s
stenbrin is offline   Reply With Quote
Old 03-23-2009, 10:12 AM   #15
Burt4x4
Burt4x4's Avatar
4" front springs
5.5" rear springs
3" bodylift
Weelwells trimed(only on the bottoms)
Rockers are gone 3x3squre tubing in it's place.
37" Irok Swampers
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-23-2009, 01:04 PM   #16
gmwoody
gmwoody's Avatar
Sorry for not explaining Center Of Gravity "COG". just a lazy typer i guess.
i really like the franken-fender job of taking two and making one. pretty engenious. i love it!!! keep em' commin!
PS how far did you move the front axle forward?
Old 03-25-2009, 03:44 PM   #17
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
heres mine.
shackle flip with longer shackle and stock height 63" rear springs in back. axle moved back about 1"
stock height 52" rear springs in front with longer shackle. axle moved foward about 2"
39.5" tsl
14 13.5 8.5 8
bmeredith is offline   Reply With Quote
Old 03-25-2009, 03:58 PM   #18
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
i am not sure how much lift i have netted from all this so i took some measurements from the top of the spring pads to the bottom of the frame rails on all four corners right were it sits in this picture. notice it is not on level ground so it's not ideal.
front pass. behind the u-bolt plate was 8.5"
front drivers behind the u-bolt plate was 8"
rear drivers in front of u-bolt plate 14
rear pass. in front of u-bolt plate was 13.5"
Old 03-25-2009, 11:59 PM   #19
onlyifihadachevy
Even if it is not ideal when it's all you can get you will still take it like my lift in the back is blocks. I have to get some other than what I have because that's just asking to break something.
Never buy a iphone they are garbage online takes forever and slow online and typing and you can't send pictures in a message.
My 72 thread
Old 03-28-2009, 10:28 PM   #20
gmwoody
gmwoody's Avatar
Bmeredith: i really like the shackle flip. did you happen to use a stock front hanger? that's what i'm planning on doing as well. nice truck! a little extreme for my plans but helpful all the same.
Old 03-28-2009, 11:29 PM   #21
bmeredith
beer 1st, work 2nd
bmeredith's Avatar
yes i did use the stock front hangers just moved it 5-6" forward to fit the longer springs. i used ORD shackle flip with a DIY4X shackle. i put the shackle flips on backwards so that the offset on each is pointed back.
