Old 03-19-2009, 08:27 PM   #1
acl
acl's Avatar
whats wrong now?
troubleshooting dash gauges and wiring. Have changed gauges and installed new circuit board.the fuel gauge still did not work. bought new one and went to install it and now the new circuit board has burnt connection from dash plug to the battery gauge?? What the @#$% am i doing wrong? I think its wired correct by looking at the diagrams Blk/wht wire and a blk wire goint to the gauge. Any help PLEASE. Gary
acl is offline   Reply With Quote
Old 03-19-2009, 09:35 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: whats wrong now?
Ttt
Member Nr. 2770
Old 03-19-2009, 11:08 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Assuming you have a 67 to 72 then it sounds like you have the black ground wire wired into the gauge instead of the blk/ brn as in the diagram below.
what's the symtoms of the fuel gauge? Empty or past full?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-20-2009, 06:40 AM   #4
acl
acl's Avatar
thanks for the response. The gas gauge just oes not work. i have changed sending unit twice, new circuit board and now new gauge. I don't think gas guage is my circuit board prob, it is just that i found it when changing gauge. I will start looking at wire again. the circuit board i changed was not burnt, i just thought it might have issues because i couldnt get the gauges to work. gary
Old 03-20-2009, 06:47 AM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Have you verified continuity on all your wires?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-20-2009, 06:51 AM   #6
Andy4639
Old member
Andy4639's Avatar
Have you checked the wire to the fuse block? I had problems a while back and it turned out the brown wire that runs through the door gutter had a bare spot in it and was grounding out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-20-2009, 08:35 AM   #7
acl
acl's Avatar
i think i got the gauge part figured out it was just finding the circuit board burnt when i went to put in new gauge. the hot spot is in the 2 contacts that are going to the battery gauge. Thats my new problem. Thanks to all. gary
Old 03-20-2009, 08:51 AM   #8
Andy4639
Old member
Andy4639's Avatar
Hope you figured it out, for get the last pm. Should have checked post first.
