Old 03-20-2009, 01:10 AM   #1
Mr. Vintage Machine
Mr. Vintage Machine's Avatar
need Alternator mounting help
I have a 68 fleetside with a 327. has power steering.
The mounting bolt in the exhaust manifold has broken.
What is an alternative way to mount the Alternator bypassing the manifold mount?
can i swithc to passenger side? how?
Need help asap!!
Mr. Vintage Machine is offline   Reply With Quote
Old 03-20-2009, 01:38 AM   #2
justtime520
justtime520's Avatar
Re: need Alternator mounting help
You can do the bracket that is sold at checkers/autozone but i believe its for a long water pump. or this style which is on my 327. heres a link to ebay (good price ) or you can go to a hot rod shop and get it new for about $100. this style bolts to driver side head Good luck. and just copy the hole thing and paste it.
http://cgi.ebay.com/ebaymotors/67-72...QQcmdZViewItem
justtime520 is offline   Reply With Quote
Old 03-20-2009, 01:48 AM   #3
mr48chev
mr48chev's Avatar
You will have to have the mounting holes in the heads to move the alternator to the passenger side plus a long water pump.
It would probably be easiest to pull the manifold off and take it to a machine shop and have them remove the broken bolt. I say that because most likely if you felt you could get it out wiith an easyout you would have already tried it.
Old 03-20-2009, 06:39 AM   #4
Andy4639
Old member
Andy4639's Avatar
Depending on where the bolt broke off is going to make it easy or hard. If it's out past the head wall then removing the manifold and get ahold of it with some vise grips. If it's flush with the head then a easy out.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-20-2009, 06:43 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Easy outs are everything but what their name implies. By the time you have the bolt smooth enough to center your drill on it and actually get a hole drilled, you have thoroughly gotten passed the really PO'd point. If you can remove the manifold, get a nut and place it up against the head and weld the nut to the bolt. The arc should not stick to the head, but to the bolt only. Now turn out the broken bolt and put everything back on.
piecesparts is offline   Reply With Quote
Old 03-20-2009, 08:07 AM   #6
jdodd68
jdodd68's Avatar
. When I bought my truck it had a similar problem. This is what the previous owner did to get by.
If I was you I would try and get the bolt out.
This is a 350 out of a 70 chevy.
50th Anniversary 1968 Chevy C10 Custom LONGBED FLEETSIDE
Facebook
jdodd68 is offline   Reply With Quote
