Closed Thread
Old 04-29-2009, 12:29 AM   #1
PBFAB.COM
PBFAB.COM's Avatar
Porterbuilt-Accuair Group Buy: 10% off and Free Shipping! Till May 31
Porterbuilt has teamed up with AccuAir to provide you guys with the most
cutting-edge air management technology available.
This group buy offer is valid for all AccuAir Electronic Leveling
Systems, and complete Air Management Packages through June 1. Group buy discount begins with a minimum of 5 leveling systems (parts that begin with "z" below).
*Electronic Leveling Systems Only:*
zAA-ELS4-RSW:
Electronic Leveling System (4-way) with rocker switch interface.
$795 list / $715.50 (with discount)
zAA-ELS4-TPAD:
Electronic Leveling System (4-way) with touchpad interface.
$1,095 list / $985.50 (with discount)
Optional items for use with any AccuAir Leveling System:
AA-RF-FOB:
Wireless Key-Fob Module (triggers 3-saved heights and all-down).
$195 list / $175.50 (with discount)
AA-VU4:
4-way 3/8" Solenoid Valve Unit.
$499 list / $449.10 (with discount)
AA-38-MUFF:
Exhaust mufflers for use with VU4 (pair)
$30 list / $27.00 (with discount)
*Complete Air Management Packages:*
zAA-AMP-1:
Electronic leveling system (4 way) with touchpad interface;
4-way 3/8 solenoid valve unit; Viair 400c; 5 gallon aluminum tank; 3/8”
plumbing kit with filter.
$1,995 list / $1795.50 (with discount) or $1,695 list / $1,525.50 (with
discount) for rocker switch interface instead of touchpad.
zAA-AMP-2:
4-way 3/8 solenoid valve unit; (2) Viair 400c; 5 gallon aluminum tank; 3/8” plumbing kit with filter.
$2,195 list / $1975.50 (with discount) or $1,895 list / $1,705.50 (with
Optional for use with either of the Air Management Systems above:
AA-WIREKIT-70A:
Compressor power wiring kit, (25 ft of 6 awg cable, 70amp sealed Maxi-Fuse, 90 Amp heavy-duty compressor relay):
$125 list / $112.50 (with discount)
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline
Old 04-29-2009, 01:01 AM   #2
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: Porterbuilt-Accuair Group Buy: 10% off and Free Shipping! Till May 31
man, that "Electronic Leveling System (4-way) with touchpad interface." is awful tempting as i'm getting ready to mount all my air hardware.
might have to have a chat with the wife (aka: banker) tomorrow.
IvelDesigns is offline
Old 04-29-2009, 01:24 AM   #3
fastbagged68
fastbagged68's Avatar
Anyone thinking about buy an air management. I would buy this one. What a deal!!!
fastbagged68 is offline
Old 04-29-2009, 01:43 AM   #4
fastbagged68
Just incase you haven't seen my video or post of the e-Level system at work, here it is... http://67-72chevytrucks.com/vboard/s...d.php?t=335036
The video is on the 3rd page.
Old 04-29-2009, 03:02 AM   #5
jasonb72
PorterBuilt Man Crush
Nate,
Once again you are the man. I will be calling you soon. I have taken an oath to stimulate the economy single handedly through Porter Built.
The 72 will live again
jasonb72 is offline
Old 04-29-2009, 07:48 AM   #6
VA72C10
VA72C10
VA72C10's Avatar
You're killing me
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline
Old 04-29-2009, 10:15 AM   #7
ShowSS12
ShowSS12's Avatar
SO will the rocker switch set-up work with my current SMC valves?
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline
Old 04-29-2009, 12:01 PM   #8
Hart_Rod
Hart_Rod's Avatar
I really don't need this right now (zAA-AMP-2), but I will eventually and the price is to good to pass up. What are the possibilities of swapping the 5 gallon tank for a smaller size and swapping one of the compressors for remote? Let me know.
R/
Hart_Rod is offline
Old 04-29-2009, 12:14 PM   #9
XXL
Seņor Member
XXL's Avatar
Originally Posted by jasonb72 View Post
Nate,
Stimulating Porterbuilt *ewwwww*
XXL is offline
Old 04-29-2009, 01:27 PM   #10
AccuAirSuspension
Junior Member
First, I want to thank Nathan @ Porterbuilt for putting this group buy together for you guys.
Now to answer some questions...
The e-Level Controller (with Touchpad or Rocker switch) is designed to work with any valves out there.... Yes even those of you with monster 1/2" diaphragm valves. The controller will learn exactly how fast your valves are during the automatic calibration and then adjust its operation accordingly.
The only thing to keep in mind is that there is a compromise in the accuracy of the RideMonitor Mode with large valves.... here is why; The smallest increment that the valve can move the vehicle is the most accurate that the RideMonitor Mode can ever be, (i.e. a minimum pulse of 60 mS on a fast-valve in the lightweight rear of a truck may equate to minimum increment of 1". So for this case the RideMonitor Mode will then automatically set a tolerance of 1". So you would have to move the truck 1" before the system would try to make a correction.) For ridiculously fast valves, the system actually disables RideMonitor Mode completely to avoid violent height changes while driving.
For the best overall system performance, we have designed the VU4 valves to be the perfect mix between speed and accuracy. This combination will get most vehicles from aired out, to ride height in ~2 seconds and allow the e-Level controller to hold a height tolerance of better than 1/8" in most cases. Plus, it's compact and leak-free design makes it the most dependable setup on the market.
AccuAirSuspension is offline
Old 04-29-2009, 01:42 PM   #11
AccuAirSuspension
Junior Member
R/
We can switch out the 5-gallon (29" long) for a 3-gallon (19" long) free of charge. Both are 6.5" in diameter and 8" in overall height with the mounting brackets. We go with the 5-gallon for the Air Management Packages because it is enough air to go from aired out to max height without waiting for the compressor(s) on most applications. Guys that don't have room for the 5-gallon will often run (2) 3-gallons for this reason.
And Yes, all tanks are available in Black or Clear Anodize. Just specify at the time of your order.
We can also swap a compressor for a remote no problem.
Old 04-29-2009, 04:06 PM   #12
jasonb72
Always the funny man....
jasonb72 is offline
Old 04-30-2009, 12:05 PM   #13
dznucks
dznucks's Avatar
Going to have to cut back on my vises until i can afford it.
dznucks is offline
Old 04-30-2009, 12:45 PM   #14
XXL
Seņor Member
XXL's Avatar
XXL is offline
Old 04-30-2009, 09:21 PM   #15
PBFAB.COM
PBFAB.COM's Avatar
We have one committed already... don't miss out on this offer!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 04-30-2009, 11:50 PM   #16
BigShoe24
True Addiction
BigShoe24's Avatar
Very, Very Interested. Let me take my change jar to the bank and see if I come up with enough scratch. I'll try to contact you Nathan, in the near future if I'm on board.
RCC
BigShoe24 is offline
Old 04-30-2009, 11:51 PM   #17
jasonb72
I sure better not be the only one that wants to get in on this. Nate, Forgot to tell you make the tank clear anodize.
jasonb72 is offline
Old 05-01-2009, 12:09 AM   #18
BigShoe24
True Addiction
BigShoe24's Avatar
I wonder if anyone has installed this system who is also running a PB drop member, as well as ART arms? Also, I have a parallel 4-Link from KP out back, wonder how that would look/work with the leveling sensors.
I think I'm just trying to figure out a reason not to buy this puppy.
RCC
Old 05-01-2009, 12:14 AM   #19
jasonb72
Quit trying so hard, I have the PB Front and Rear DM, I do not see any issues yet why it can not work in many different configurations.
jasonb72 is offline
Old 05-01-2009, 12:31 AM   #20
IvelDesigns
I got the green light to get the parts i "need" to finish the truck, but unfortunately, this wasn't one of them. Maybe next time...
Old 05-01-2009, 12:41 AM   #21
PBFAB.COM
PBFAB.COM's Avatar
Leveling sensor installation is straight forward.... how about thinking of all the reasons TO buy it!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-01-2009, 10:56 AM   #22
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Those tanks are BEAUTIFUL...
BTW, Jeff has this on his "E-Rod"..... So bad ass, awesome product.
AVS_JASON is offline
Old 05-01-2009, 03:58 PM   #23
Hart_Rod
Hart_Rod's Avatar
In. PM and email sent.
Hart_Rod is offline
Old 05-03-2009, 11:53 PM   #24
hammered65
Just curious if the Electronic Leveling System will work with ART RidePro valves?
hammered65 is offline
Old 05-04-2009, 12:11 AM   #25
jasonb72
It was stated that the system will work with all other valves, as it actually learns what ever system is used in conjunction with it.
jasonb72 is offline
Closed Thread
