Old 12-28-2002, 07:03 PM   #1
CustomMike
heads
I have a set of heads off of a 350 with 333882 stamped on them. I would appreciate any information on them. I know they have 1.94 intake and1.5 exhaust valvesbut I don't know the cc chamber. Are they good or bad and what horsepower motor would they be bolted on to.
CustomMike is offline   Reply With Quote
Old 12-28-2002, 07:10 PM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Those are what some call " light weight heads" Beware of cracks in the center exhaust seats, VERY common
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is online now   Reply With Quote
Old 12-28-2002, 07:47 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There were some light, and some heavy.
As far as smogger heads go, these are some of the better flowing ones. Even the light ones will hold up OK...I had my light 882's (on my GMC with some porting done to them) up to 260 degrees once if memory serves. I lost a fan belt out on the freeway and I was doing about 80 - 85 MPH.
They held up just fine. Not that I would recomend yankin off your belt to test them...
Old 12-28-2002, 08:02 PM   #4
mikep
Used to have a truck
mikep's Avatar
flow figures for those heads
.100" lift intake ... 70 CFM
.100" lift exhaust... 59 cfm
.200" intake... 125 cfm
.200" exhaust... 109 cfm
.300" intake... 178 cfm
.300" exhaust... 136 cfm
.400" intake... 204 cfm
.400" exhaust... 143 cfm
.500" intake... 205 cfm
.500" exhaust ... 144 cfm
Ideally you want your flow numbers to be in the 75 % exhaust to intake. Those heads are pretty close although your ports start restricting flow around .400" of valve lift. Your best best wold be a fairly sraight pattern cam with somewhat equal duration and lift in the mid .400" lift range and around 215-225 degrees at .050" duration. With a performer intake or something similar and a 600 cfm carb you'd be looking at around 325 HP or so. Running it through the desktop dyno I picked up 332 HP with a comp cams XE 268 and 378 ft lbs of torque at 3500 RPM using small tube headers and duals
No truck :-(
mikep is offline   Reply With Quote
Old 12-28-2002, 08:03 PM   #5
flyin99
creator of kong
flyin99's Avatar
A majority of the small blocks I have rebuilt for people, seemed to have 882's on them. They must have been very common. I also read somewhere, that they were considered "the best of the worst"...........
flyin99 is offline   Reply With Quote
Old 12-28-2002, 10:29 PM   #6
67/72junkie
heads
They are 76cc and are good heads for street usage on pump gas .Make sure you have a set with a 1976 or later casting date so they will have hardened seats for unleaded gas.If not you will have burnt valves before long.
67/72junkie is offline   Reply With Quote
Old 12-28-2002, 10:37 PM   #7
jmanz69
Careful, they attack...
jmanz69's Avatar
I have a set of these in my garage right now that I have been trying to get rid of for a while. I thought the were decent heads but I kept hearing that they were awful. I bought them cuz they were better than the 305 heads I had on. They are just empty castings right now waiting for new parts. Should I keep them and have them worked on or sell them cheap?
jmanz69 is offline   Reply With Quote
Old 12-28-2002, 11:02 PM   #8
bigjimzlll
bigjimzlll's Avatar
if you have them worked...valve job..tanked..new seats..valves ..retainers..springs ..seals..locks..you will be looking at over 300.00 and all you will have is a set of mediocre stock heads..if you do a bowl port job..thats 200.00 more..for a couple of hundred more you can get some nice aftermarket heads...
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
