Active Member
Rear end cover Alum - who is running This one
I am looking at an LPW rearend cover - maybe a TA
Is anyone running one of these? Does the panhard bar get in the waY
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Re: Rear end cover Alum - who is running This one
That is a awsome rearend cover.
i believe there's panhard clearance issues with covers like that
![]() Join Date: Feb 2008
Yeah, I think the standard panhard bar will have clearance issues. ECE makes a bar with a bend in it that allows you to use the aluminum covers.
1967 Chevy SWB 1972 Chevy SWB 1972 Chevy SWB K20 4x4 1991 Ford F-150 2013 Dodge Ram 1500 4x4 Last edited by lchall; 05-11-2009 at 09:25 PM. |
resident oilfield trash
Its CPP that makes that bar and it still didnt clear
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
![]() Join Date: Jul 2003
ECE makes bars that have a bend in them for bigger alumn covers now, or you can get the bar and cover both from them.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
Active Member
I bought one of the LPW covers today - the term no way is this sucker going to fit came to mind when I climbed under the truck- the stock rear cover leaves only 1/2-3/4" clearance - the LPW is 1.5 inchs taller than a standard rear cover - so Jegs will get another return
