Old 06-03-2009, 04:07 PM   #1
53choptop
57 Chevy progress - Camaro Subframe is in
Hi guys,
Been working on the 57 on and off after shortening it from a LWB:
http://67-72chevytrucks.com/vboard/s...69#post3083769
I installed the camaro subframe this past week. It took longer than expected, but its in.
This board and the HAMB help out a bunch, after piecing together post of others getting this done i got the overall picture, and yes it is 28 1/2 inches from the front body mount, I doubted some of the posts measurements and it ended up costing me alot, actually several days of more work.
In the pics its sitting on 2x4's high enough to get the jack into it, the 14 inch wheels don't help either, plus the fact that its still on the original rear end height and tires does not help. But its a roller. Next I am going to rebuild the suspension, bodwork, blah, blah, blah. This thing is going to be a budget beater.
I order to tackle the front frame horns, I welded pieces of metal to hold up the horns when I cut them off the frame, marked the garage floor and when the clip was on I lined it all back up, it aint pretty when you line it back up cause the subframe is wider up front, but all of that is hidden behind the radiator support and such.
This build is alot of fun. I am really getting into it. I will keep posting as I go along. Let me know if you have any questions.
Also I am looking for 15 inch 5x4.75 steel wheels, anybody got a spare set in the austin area? how about a 4wd s10 sonoma, jimmy rear end with disc brakes?
53choptop is offline   Reply With Quote
Old 06-03-2009, 04:10 PM   #2
53choptop
Re: 57 Chevy progress - Camaro Subframe is in
I am missing alot of pics, i really didn't slow down to take too many so this is cut and dry version.
i need to get that rear end down, the truck looks like its going to tip over
Old 06-03-2009, 05:53 PM   #3
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
NOW that rake!!! im in love hahaha Seriously dude Great Work
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 06-03-2009, 05:57 PM   #4
Kim57
Kim57's Avatar
Nice work. keep the pics coming.
Kim
Kim57 is offline   Reply With Quote
Old 06-03-2009, 07:59 PM   #5
mr48chev
mr48chev's Avatar
Nice work, it looks like you are on your way to having it right.
Old 06-04-2009, 07:21 AM   #6
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice work! This is how my frame horns were done. It required a lot of cutting heating and bending of the sub-frame, but the end results look great.
ChuckDriver is offline   Reply With Quote
Old 06-04-2009, 11:51 AM   #7
53choptop
Thanks CD, your truck looks great and actually your pics were the some of the ones I was looking at closely to try to figure out how to graft the front horns on. But because the clip went in differently, the horns do not line up as nicely. They are alot lower I will try my best to make it look decent, but with the amount of metal work on something that you really cant see it will be more functional that pretty.
I will try to follow JML55's example in post #23, his look really good, but as you can see its alot of work.
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
Old 06-04-2009, 07:37 PM   #8
ChuckDriver
Yep JML55 does some awesome work! Keep at it and keep us posted!!
Old 06-04-2009, 08:18 PM   #9
JML55
JML55's Avatar
Nice work, its coming along good. I'm trying a Blazer 4x4 disc brake rear diff set up right now and my only concern is the width if you want the low raider looks you need to tub because the calipers are in the way, they are narrower that the box sides.
Thanks for the compliments guys.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 06-05-2009, 10:01 AM   #10
53choptop
What are you guys paying for a 4x4 disc brake rear end now-a-days? I don't frequent junkyards anymore, maybe I'm getting old, but I dont really want to deal with that when i know I can buy stuff behind a computer....
Old 06-05-2009, 01:13 PM   #11
JML55
JML55's Avatar
Paid 300$ for mine and put in an other 300$ in new parts in it. New seals, bearings, brakes, and hoses.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
Old 06-05-2009, 02:28 PM   #12
Kabwe
Certified Car Nut
Kabwe's Avatar
Well I paid 200 for a posi 8.5 10 bolt out of a Chevelle. I put about another 600 in it because I added disc brakes and narrowed it using moser axles and housing ends. You can see how I did it in my build thread.
Nice Olds, I've always like them. You can take a look at my 55 Sedan at the link below.
Kabwe is offline   Reply With Quote
Old 06-12-2009, 03:57 PM   #13
53choptop
Thanks, that's about the prices I am getting, of course there are people out there that think they found gold thinking and are going to get $500 for one just because its a disc unit, heck not even posi....
