![]() Join Date: Jul 2007
U Bolts - What Size??
I need some new rear axle u bolts for my 67 1/2 ton with a 12 bolt rear. I found the link (that someone posted) to the place that sells them but I don't know what size I need.
Does anyone know what size I need order?? Thanks!!
It's Not Rust, It's Patina!! 1967 ![]() 2008 ![]() |
Re: U Bolts - What Size??
don't you have a ruler?
Nothing to see here.....
![]() Join Date: Jun 2007
Perry,
Do you need diameter, or center to end of leg.... or both? I'll see what I can get for you.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 06-04-2009 at 12:39 PM. |
Whats the link to the site?
Under Construction
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
I found 2 sources online. Yes I have a ruler but I thought someone may have already done the measurements and have some valuable input.
http://www.generalspringkc.com/index...parent=32&pg=1 http://www.stengelbros.com/U-boltKits.htm
#7 | |
If I read the link from TX Firefighter correctly, they should be 20" long (total length) and 5/8" in dia. with a 3" tube diameter. So basically I've answered my own question. Does anyone agree with these measurements?? Thanks for all the input!!!
I'm thinking stock was 3/4 dia.
TTT
Can anyone confirm these dimensions?? Thanks!!
OK,
Here is what I came up with. "A" is 3/4 NF "B" is 3 1/2" "C" is 7 1/2" These measurements are from a '69 C-10, 2 wd, oem coil spring rear end.
I had a local spring shop bend new one's...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
