Old 07-07-2009, 06:45 AM   #1
ECU PIRATE
ECU PIRATE's Avatar
Glove Box replacement
Does any one know how to remove the locking mechanism on a glove box? I just got a donor glove box for my 82' but can't seem to separate the box itself from the metal door.................
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 07-07-2009, 11:00 AM   #2
OrangeAnimal
OrangeAnimal's Avatar
Re: Glove Box replacement
Do you have a locking one or is it just a latch? Let me know and I can take a look at mine to refresh my memory I just had mine apart a month ago.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 07-07-2009, 11:20 AM   #3
ECU PIRATE
ECU PIRATE's Avatar
orangeanimal,
Just the latch. I saw a post on here awhile back and printed it out but, I think I either lost it or my wife threw it away
The Fleet........
Old 07-07-2009, 11:34 AM   #4
Keith Seymore
Keith Seymore's Avatar
I just did mine (non locking) a few weeks ago.
Just gently pry the lock portion out of the housing (I'm talking about the chrome knob: you can either pry under the chrome part or you can pry at the base of the latching mechanism). Once that is out then there is a threaded lock nut on the metal (glove box door) side that you unscrew from the latch housing and you are all set.
Make note of how it all comes apart because you will have to put it back together and get the spring wound correctly so that the latch works when you slam the glovebox closed.
(It's not as hard as it sounds here).
HTH -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-08-2009, 09:40 PM   #5
bigblock73
yeller
bigblock73's Avatar
A copy and paste of my response to Keiths very same question in his own thread
Guys, taking the latch off is super easy.
All you have to do is unscrew it from the inside of the glovebox liner. The actual knob has to be in either the open or closed position, I can't remember, but the inside latch will only spin in 1 of the 2 positions. When unscrewing it, simply pull back slightly, away from the knob...and it will simply unscrew.
No tools required.
I have dont no less than 10 of them this way, worked every time.
bigblock73 is offline   Reply With Quote
Old 07-09-2009, 12:50 AM   #6
ShowSS12
ShowSS12's Avatar
damn that simple huh? I couldn't figure it out to save my life so I just broke the chrome "handle piece" off. Oh well time to order a new one...
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 07-09-2009, 09:15 AM   #7
Keith Seymore
Ouch.
I have only done the one, but I did it about 50 times...
(putting it back together - and getting it to work right - was harder for me than taking it apart).
K
1979-1986
1986 - 2019
Old 07-09-2009, 10:56 AM   #8
ECU PIRATE
ECU PIRATE's Avatar
No tools required.
Thanks bigblock73. I will give this a try. I could figure out how to do it once I started trying to replace my current box with the donor. You wouldn't happen to have the template you used for the factory speaker pods you got from Russell would you? I just pulled the same set up off of a 80" Surbuban that I am going to put on the donor doors (77' vintage) on my 82'
Thanks,
Mike
The Fleet........
Old 07-11-2009, 10:07 PM   #9
bigblock73
yeller
bigblock73's Avatar
Thanks,
Mike
Mike, I don't have a template, but if you PM Russell, he might still have them hosted and might be able to send you a link. Try that first, if no luck, I can measure mine for you...but Russell had some nice clean pics for me to go off of.
Old 07-15-2009, 06:41 AM   #10
ECU PIRATE
ECU PIRATE's Avatar
Thanks bigblock73. I still have the original door panels from the Suburban and started working on a template last night. I am trying to figure if it would be better to make it from the inside or outside of the panel. I will try Russell and see if he can help.
Mike
The Fleet........
Old 08-05-2009, 07:04 AM   #11
ECU PIRATE
ECU PIRATE's Avatar
Worked like a charm..............thanks guys
The Fleet........
Old 10-24-2009, 06:20 PM   #12
joe231
joe231's Avatar
I know this shouldn't be this hard.....I have done it before but can't get it to come apart. I can get it to unscrew but it is still captured. I remember something about you need to push in on something to get the knob assembly to come apart from the latch, correct. someone please help....
CHEVY ONLY
Old 10-25-2009, 12:20 AM   #13
joe231
joe231's Avatar
Nevermind....figured it out
CHEVY ONLY
