07-28-2009, 08:00 PM | #1 |
will 86 caprice spindles bolt up to a 67 pick up
i have an 86 caprice classic and i was wondering if the spindles will bolt up to my 1967 chevy c-10
07-28-2009, 09:49 PM | #2 |
Re: will 86 caprice spindles bolt up to a 67 pick up
Never heard of anyone trying this swap and I would question the strength of passenger car spindles on a truck. However, if the height is similar and the ball joints will fit properly with no slack, then they should physically bolt up.
07-28-2009, 10:06 PM | #3 |
its all about the +6 inches
wouldn't surprise me....
i have to wonder why though. |
07-28-2009, 10:10 PM | #4 |
i was just wondering cause i wanted to covert to 5 lug and i didnt wanna spend the money on new ones
07-29-2009, 12:13 AM | #5 |
There's more to it than just being able to bolt them in.
The steering arms are integral to the spindle. Caprices (b-bodies) have different suspenion geometry vs. trucks & thus the steering arm would likely have different requirements (different height, different length, different arc, etc....). If it's not correct (or as close to it as possible) there could be severe steering related issues.
07-29-2009, 12:47 AM | #6 |
so what spindles could i get from a junk yard to bolt directly up too it with out spending a ton of money
07-29-2009, 12:56 AM | #7 |
Stock disc spindles from a 71 or 72 are fairly easy to find. Also, lots of guys upgrade to dropped spindles and sell their old ones on Ebay or Craigslist for cheap.
07-29-2009, 12:57 AM | #8 |
I put spindles on mine from late 70's or early 80's half ton. I did this for the same reason as you are and also for disc brakes. I did have to change the lower ball joints but they're 25 bucks each. The biggest part is getting the brakes set up if you haven't already done that.
81 Blazer 69 C-10 |
07-29-2009, 01:02 AM | #9 | |
07-29-2009, 07:24 AM | #10 |
BOHICA
I haven't personally done it, but a lot of guys here take the whole front end off of a later 70's or 80's square body. I hear it bolts right in. there are like 14 bolts that you have to remove and the whole thing comes out. That way you get the spindles, brakes and all in one chunk.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
07-29-2009, 09:02 AM | #11 |
Yes. Front suspensions from 71-87 (5-lug) are a direct interchange w/the 63-70 front suspensions. Try finding an earlier year model if possible (pre-81) or if it's between 81-87, measure the rotors because you want the 12x1.25" rotors/spindles. They also come in a light duty 12x1.00" version which uses a different spindle & the rotors are more prone to warping.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-29-2009 at 09:03 AM. |
07-29-2009, 09:54 AM | #12 |
If you get the whole setup from a new truck, get the proportioning valve and possibly the master cyl. too.
