Old 08-05-2009, 11:00 PM   #1
mike73
mike73's Avatar
Question A lil help please....
Ive got a 66 with an 84 Burban X-member.I need to replace front coils. Whats the SAFE driveway method?
mike73 is offline   Reply With Quote
Old 08-05-2009, 11:07 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: A lil help please....
First, you jack up the truck high enough to allow the lower arms to drop, and support on stands. Level ground and wheels blocked.
Disconnect shocks and sway-bar (if equipped)....
Remove up upper ball cotter pin, and loose nut about half way, but do not remove. Hit spindle along side nut, untill itg "pops" loose.
Place jack and lower a-arm and raise to releive tension, and remove nut.
Lower jack slowly and remove spring.
Install, is basically the reverse, you just don't need to bang anything (usuallly)
I would have a a second person help you mabey with the jack.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-05-2009, 11:33 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
What John said, however I also like using a spring compressor especially when installing the new springs. You can rent them from most auto supply stores although they aren't that expensive if you'll ever use it again.
It's also a good idea to wrap a chain through the spring and lower control arm just for safety in case the jack slips and the spring comes out under pressure.
Old 08-05-2009, 11:55 PM   #4
mike73
mike73's Avatar
And that folks is why I love this place! Same day service! Who needs ALLDATA when we have a fine group like this! Thank you both very much!
Old 08-06-2009, 07:17 AM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
and those springs travel a LONG way if they get lose from you!
I've seen one at least 20-30 ft in the air.
Old 08-06-2009, 07:24 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Good idea for the first timer...however, personally I've never had an issue wih removing coils from the front-ends...Mabey because in my side on town, all the springs were heated !! (JK)
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-06-2009, 09:42 AM   #7
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah - we like it too, and that's why we advise subscribing.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 01-10-2011, 01:06 PM   #8
Ynotnow817
Ynotnow817's Avatar
Great info guys. Any tips on doing this on a front suspension that is not under a truck yet?
Ynotnow817 is offline   Reply With Quote
Old 01-10-2011, 02:41 PM   #9
CVA59
Coil Spring Compressor is the safest way
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 01-10-2011, 02:43 PM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Spring compressor from Oreilly's or your favorite parts house. Rent one so you dont loose an appendage/life when you mess with the springs.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-10-2011, 03:28 PM   #11
Ynotnow817
Ynotnow817's Avatar
thanks
