Old 08-21-2009, 01:07 PM   #1
69_C10
Doing it my damn self.....
69_C10's Avatar
2-Part Control Arms Question
Part A - I'm in a frame off project and starting to re-assemble my suspension to my frame. I had my control arms powdercoated. I don't want any squeaks etc when re-assembled. How do I know if I need to replace the shafts of my control arms? Any tell-tell signs to look for?
Part B - How do those shafts come out of the control arms? I'm assuming they screw off of the ends. The powder coater really laid the powder to these and probably are stuck in place. Any particular method of removing\replacing the shafts?
Thanks Guys - I really appreciate you.
Mark Ingle - Asheville, NC
Mark...
Project 69 Stepside...http://67-72chevytrucks.com/vboard/s...d.php?t=290761
69 C10 Stepper - Current Build
94 Silverado - Driver
05 Hummer H2 - Unique Whip
69_C10 is offline   Reply With Quote
Old 08-23-2009, 10:28 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: 2-Part Control Arms Question
Bump
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-23-2009, 11:04 AM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
best I can tell yea is change them out now it's alot easier than after your done putting it together.....as far as the powder coating I would take a hack saw blade and cut the powder coating clean then UNSCREW one end at a time and change them out he must have had a hell of a time with the old grease in the arms coming out during the heating??? anyway you can just touch out the new ends with some paint and put some good grease in them
If your in this deep you alreadt knew this just needed a kick in the pants..lol
Hottrucks is offline   Reply With Quote
Old 08-23-2009, 03:45 PM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Yes, they screw out.
Now, the bad news. They can be a ***** to to unscrew. Some heat and an impact gun are your best bet. (yep, I know you had them powdercoated already)
You should replace them... IMO.
Tom Vogel is offline   Reply With Quote
Old 08-24-2009, 09:04 AM   #5
69_C10
69_C10's Avatar
Thanks guys. I appreciate it.
Mark...
Old 08-24-2009, 01:12 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Find another powdercoater. Your guy is a hack.
There are rubber seals on the shaft for the bushings. He should have stripped the arm of all components prior to coating them. You now have an arm with bushings with cooked grease seals and dried grease cooked inside of the bushings.
Sorry if I seem confrontational, but I can't stand to read things like this. It gives powdercoating a bad rap and that hits me personally.
Old 08-24-2009, 01:54 PM   #7
SCOTI
SCOTI's Avatar
I've seen more than one guy post up pics of their freshly coated parts & the BJ's/bushings were still installed. I thought why would someone compromise something like the finish on a part (a part they just did!). I can't stand it either & I'm not a coater .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
