Old 08-24-2009, 06:20 PM   #1
vegaschevy
pics of brake booster to aftermarket intake please!
Any pics of how you hooked your brake booster up to an aftermarket carb & intake?
The factory rochester has it threaded in to the carb, an aftermarket carb does not allow this so you have to do it into a port, what insert? what line? what did you use and how? pics please.
vegaschevy is offline   Reply With Quote
Old 08-24-2009, 06:27 PM   #2
Ben IV
Re: pics of brake booster to aftermarket intake please!
carb should have a large vacum port just hook the hose to that or a fitting on the intake runner. I know hollys and edelbrocks have the large port for either brake booster or pcv valve.
70 GMC custom short bed conversion
69 GMC panel truck
Ben IV is offline   Reply With Quote
Old 08-24-2009, 06:33 PM   #3
BCOWANWHEELS
Put a plate under the carb with a inverted flair fitting. Going to 1 port is not as good as going under the carb base.
Bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-24-2009, 06:51 PM   #4
mclairmo
Or, hook it up to a 90 degree fitting screwed into the manifold like the ones here.
mclairmo is offline   Reply With Quote
Old 08-24-2009, 07:57 PM   #5
vegaschevy
BEn IV was right, There was a brass fitting plug on the back of the carb for it. Got it on and now ran in to another problem. LOL
Ill start a new thread about this one.
