08-31-2009, 07:51 AM | #1 |
Mad Scientist
05 airbag lite on
My dad calls and says his 05 Silverado 2wd halfton has the airbag lite on. I told him to check the codes and he says 441 which I think is recir solenoid. Anyway....no air bag code (and no engine lite for other code) Ideas on what's going on?
Everythang relates to Beer! 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
09-02-2009, 05:47 PM | #2 |
Re: 05 airbag lite on
i tired lookin up that code and there is no code listed for 441 under air bags on shopkey
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-04-2009, 10:16 AM | #3 |
Mad Scientist
the 441 code is an emissions code. Seems the air bag might have an issue with the plug behind the drivers side kick panel?
09-08-2009, 07:11 PM | #4 |
You cant pull an airbag code from the ecm you need to get into the airbag module and pull the code stored in there.
09-11-2009, 05:09 PM | #5 |
try wiggling the airbag harness under the driver side seat, see if the light goes off, every GM with an air bag light on ive had, it seemed there was a bad contact with that harness. its probably not whats makingyour light come on, but its a free diagnosis.
1967custom |
09-13-2009, 08:34 AM | #6 |
Has he had an accident, was the truck wrecked ? If he bought the truck new and the answer is no, you might be able to get the dealer to take care of it under warranty (worth asking about). If it has been hit and was covered by insurance, then if they can deem it wreck related the insurance should pay to fix it. Just a few options. James
09-18-2009, 10:12 PM | #7 |
check the harness from the sensor under the seat. It goes from the sensor to underneath the sill plate then to a connector behind the kick panel. I have run into some that the wire has corroded or broken under the sill plate because dirt and moisture stays under the sill plate and eventually corrodes the wire harness. However getting the code would help narrow down your problem.
10-01-2009, 02:37 PM | #8 |
I just had that problem with my 05 Suburban Z71. I had to replace a sensor in the front bumper for $75.
