09-07-2009, 11:48 PM | #1 |
Throttle Linkage Question
I installed a Edlebrock carb and curious if guys are using the stock solid rod throttle linkage or using something else. Any one running the Lokar universal set up? Any pics if you are using the Lokar linkage? This is what I am thinkng of using.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, 2009 Acura MDX |
09-07-2009, 11:56 PM | #2 |
its all about the +6 inches
Re: Throttle Linkage Question
i have edelbrock 750/electric choke carbs on both my trucks with stock throttles... rod on the longhorn and cable on the burb
09-08-2009, 06:57 AM | #3 |
Watch out for your cornhole !
I buy two of these...
and a length of 1/4 inch rod. Use a die to cut thread on the ends of the rod and assemble. This gives you a very smooth pedal feel and the height of the pedal off of the floor can be adjusted by shortening or lengthening the rod. Total cost is about 10 dollars. Much cheaper than buying Lokar.
09-08-2009, 08:37 AM | #4 |
Throttle rod and Edelbrock carb. Edelbrock makes a piece just for this application. It is called a 'throttle rod stud' or 'throttle rod shoulder stud'.
I purchased one when I bought my carb. Pictures of it on my truck can be seen here: http://67-72chevytrucks.com/vboard/s...60#post1567060 The way I figure it Edelbrock pays people good money to solve common problems - one of them being hooking up an old throttle rod stud to one of their carbs. They came up with this stud and it has worked flawlessly for me since day 1.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
09-08-2009, 12:13 PM | #5 | |
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
09-08-2009, 01:28 PM | #6 |
Old Skool Club
The Edelbrock 600 that was on my truck when I bought it ten years ago had piece of all-thread that was bent on the end that attached to the carb..... while it got the job done, it just looked like my old shade tree lawnmower buddy had a hand in hookin' it up.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-08-2009, 05:27 PM | #7 |
landarts
The truckshop has them for $31, http://www.truckandcarshop.com/trucks60_72/t60_094.html
09-08-2009, 11:35 PM | #8 | |
09-08-2009, 11:56 PM | #9 |
I've done this twice, it worked on my 1411 and now I have it on my TBI. Smooth as butter. It's similar to TX's solution, but a little more $$ since it comes with some extra stuff. The springs are pretty strong.
http://www.bakerprecision.com/longacr53.htm
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
09-09-2009, 07:22 PM | #10 | |
08-11-2011, 01:57 AM | #11 |
what is that part called in tx firefighter post? and who sell them? auto part store or hardware store? home depot dont carry them
08-11-2011, 02:05 AM | #12 |
~Rest In Peace~
you can come down to petaluma ,sonoma county street rodz can help you ask for jeff
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
08-11-2011, 02:09 AM | #13 |
sounds good they open sat?
