Old 09-21-2009, 03:47 PM   #1
mplex2000
mplex2000's Avatar
Truck and SBC Parts
Anything small in here I don't mind shipping to you if you don't mind paying the shipping. I live near Fort Worth so you are welcome to pick them up, or if they fit in my car I work out by Dallas and I'd be happy to meet you.
ALSO - I am up for trades. Need plenty of parts for my truck. Big block stuff, body parts, even trailing arms. Let me know what you have!
Also guys if you see something I've priced too high (or too low!) please let me know. Some of this stuff I'm just unsure on what it's worth.
4bbl factory iron intake manifold from a 78 454. Spreadbore, engine had 781 heads so this is not for peanut port heads. Quite nasty, needs a good cleanup.
$25
Fel-Pro Engine Gasket Set, 400 SBC
I tossed out the junk cork pieces for the valve covers and oil pan. I will include a set of steel core silicone valve cover gaskets. Was going to use this on my 406 build but I changed directions.
$80
New chrome alt bracket set, for LWP, SBC
$15
New Polished Alum P/S pump bracket for LWP, SBC
$20
New aluminum long water pump for SBC. I believe it's a Proform.
$50
New Edelbrock polished aluminum SBC timing cover. Dusty, but not used.
$55
Black jack SBC headers, came on my 69 c10.
$50
Unknown auto floor shifter, also from my truck but obviously came from some car.
$25
K&N filter and recharge kit, $33-2129 was used for about 10k miles in a 2004 Tahoe.
$35
Clutch/Brake pedal assembly. This was out of my 3 on the tree 69 c10.
$25 ?
71 ( I think, maybe 72?)
Truck 12 bolt, housing and axles (5 lug) only, no cover, no wheel studs, etc. Was going to use this but I'm afraid my motor will tear up a stock axle. From a coil spring truck. Again, housing and axles ONLY, no gears or other parts. I do have a new set of Timken axle bearings I will throw in with this.
$150 obo
I also have various factory A/C parts to post. To be honest I don't know much about A/C systems so I'll have to do some research to even know what they are called
mplex2000 is offline   Reply With Quote
Old 09-21-2009, 04:14 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Truck and SBC Parts
can I see a better pic of the shifter assy? Im interested in that
1967custom
michael bustamante is offline   Reply With Quote
Old 09-21-2009, 07:56 PM   #3
jlive68
Is the rear end off of trailing arms or leaf springs. I am interested in it. what is the gear ratio if you know.
1968 chevy
U.S. Navy
jlive68 is offline   Reply With Quote
Old 10-01-2009, 09:49 PM   #4
SS68
SS68's Avatar
do you still have the headers? i work in carrollton until 6pm would love to have them tomorrow.
SS68 is offline   Reply With Quote
sbc 350 c10
