Old 09-29-2009, 01:24 AM   #1
Shamil
Shamil's Avatar
Mag Lug nuts
hello people, i need your help
i have an old aluminum rims as in the picture. the lug size (whole size) diameter is about 17mm deep 1"
i want to install them on my truck, the truck has a stock studs, front axle d60 rear axle FF, what mag size should i install
Shamil is offline   Reply With Quote
Old 09-29-2009, 02:45 AM   #2
fire120ball
fire120ball's Avatar
Re: Mag Lug nuts
I am not an expert but i'm pretty sure whatever size your studs are... the lug nuts you will be gettting are a normal lug but it has a cone seat on the end, and long as those wheels have a coned one on it also.
fire120ball is offline   Reply With Quote
Old 09-29-2009, 04:05 AM   #3
Shamil
Shamil's Avatar
Re: Mag Lug nuts
would the one in picture fits in
Name:  STANDARD MAG LUG.jpg
Old 09-29-2009, 07:54 AM   #4
Shamil
Shamil's Avatar
Re: Mag Lug nuts
any one
Old 09-29-2009, 09:40 AM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Mag Lug nuts
Check out lugnutguy on ebay. I bought a full set for an old set of e/t slots I bought
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 09-29-2009, 09:45 AM   #6
nlped
nlped's Avatar
Re: Mag Lug nuts
The lugnut pictured is close, but it may be a tad to long. You do have to use them with a mag shank washer which may shorten the shank enough to work with that wheel. You don't want the lug nut going through the wheel more than 7/8's of the way, but at least 3/4's of the way. If it is to long it will bottom out on the hub and the wheel won't tighten completely. And if it is to short it will not hold the wheel in a fixed position (i.e. the wheel can rotate slightly and cause major issues).
Another option, if you are deadset on using these wheels, is to buy some steel conical inserts to facilitate the use of standard acorn seat lug nuts. I have done this on a few set of older wheels that came with this old style lug hole. The wheels lugholes have to be bored to the proper size for the seats and then just press them in. Just another possibility.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-29-2009, 01:08 PM   #7
Shamil
Shamil's Avatar
Re: Mag Lug nuts
from the site http://www.cwausa.com/MagLugNuts.html
which one fits my rims
Old 09-30-2009, 06:02 PM   #8
fire120ball
Re: Mag Lug nuts
If the lug on that rim has a flat surface on the hole you need mag shanks if you know what I mean its hard to explain but if there is a cone seat you need lugs to match the cone seat
