Old 09-30-2009, 08:19 PM   #1
Number21
Number21's Avatar
Factory hub caps on aftermarket wheels?
I have a '79 1 ton with the stock white painted 8 lug wheels and Chevy hub caps. Somebody replaced the back wheels with 16" instead of 16.5, they're just cheap white painted steel wheels. I have the full set of 4 caps, is it possible for me to attach them to the aftermarket wheels? If I hold the cap up to it, it almost matches the front wheels. I'm just not sure how I'd attach it? And, would I have to have the tire/wheel rebalanced?
I'm going to get a new set of wheels and tires eventually, but for now I want to spend all my cash on the engine.
Number21 is offline   Reply With Quote
Old 10-01-2009, 07:57 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Factory hub caps on aftermarket wheels?
Sounds like you would be better off hitting the local new/used tire and wheel shop to see if they have any thing to fit your needs.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-01-2009, 11:21 AM   #3
Keith Seymore
Keith Seymore's Avatar
I have an idea but need to make sure we are talking about the same cap. Can you post a pic of the wheels and caps in question?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-01-2009, 11:29 AM   #4
Damien
Damien's Avatar
Gm made 16" wheels for the 3/4 ton that use the dog dish hub caps. I'm assuming that is what you have?
No, the wheels are not balanced with the hubcaps on.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 10-01-2009, 03:40 PM   #5
Sniper X
I have both split rims on the 74 and regular wheels (stock) on the 78. The hub caps on both will fit both, the split rims are 16in too, not the 16.5's, and I actually have the hubcaps off the 78 on the 74 split rims till I buy new non split rims for the 74.
Sniper X is offline   Reply With Quote
Old 10-01-2009, 10:40 PM   #6
Number21
Number21's Avatar
K
I can't take a pic of the caps right now, they're down at my shop, but they look just like the ones on this truck:
http://www.67-72chevytrucks.com/vboa...d.php?t=337315
This is the aftermarket wheel, you can see why I want to cover them up.
Just to clear things up - the truck came with four 16.5" wheels/caps. (8 lug) Somebody replaced just the rear wheels with 16", probably since 16.5" tires are so expensive. The front wheels are original. I'll probably replace all 4 with 16s eventually, but for now I don't really want to spend any money on them.
Old 10-02-2009, 07:24 AM   #7
Keith Seymore
Ok - thanks. I was picturing something totally different.
K
1979-1986
1986 - 2019
Old 10-02-2009, 10:50 AM   #8
Sniper X
A hub cap won't fit on those wagon wheels. They look good just refinished though.
Old 10-02-2009, 08:06 PM   #9
Number21
Number21's Avatar
The ones I have "fit" just fine, it's just that there's no way to attach them. Anyone have any thoughts on that?
Old 10-03-2009, 09:14 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
There isnt a easy way... But metric studs from a newer truck have threads to attach the plastic nut to hold the factory cap on. thats the way my 98 2500 is. Not easy but possible Thats how my dad did his on a half ton
KQQL IT is offline   Reply With Quote
