Old 10-02-2009, 08:16 PM   #1
Estanley
Estanley's Avatar
Can anybody ID this wheel?
15 x 8.5 universal wheel has US patent # 3329466 on the back
Estanley is offline   Reply With Quote
Old 10-02-2009, 08:56 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Can anybody ID this wheel?
I'm guessing the patent has something to do with the uni-lug.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 10-02-2009, 09:28 PM   #3
fiddy9apache
fiddy9apache's Avatar
looks like an old american racing wheel
fiddy9apache is offline   Reply With Quote
Old 10-02-2009, 10:02 PM   #4
CSGAS
optomistic ah-so
CSGAS's Avatar
US patent # 3329466 pertains to a load-bearing structure, specifically a seat, constructed on webbing with cushion padding, filed in Feb 1967...so something doesn't match up there.
The actual wheel looks like something Ford Motor Company used to outsource from Keystone wheels, which would explain the unilugs, and most often appeared on 60's and early 70's Lincolns--in case anyone is thinking it, I'm not referring to the later ones with the Lincoln insignia in a hex shaped center, these are earlier "optional Mag" wheels. The Lincoln would not be the only application, as Keystone made the wheels.
That's what it looks like, but I am not guaranteeing that's what it is!!! Where's the smiley with the mouth shut?!?
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 10-05-2009, 08:46 AM   #5
hot trux
'85 Stepside
hot trux's Avatar
My brother had a set of those on his 57 hard top ...they were ET brand. I believe they had push in caps (snap in).
hot trux is offline   Reply With Quote
