Old 10-04-2009, 03:45 PM   #1
blackmopar
firewall hei dizzy recess
hey guys - looking for an easy idea to clear fireall for adding an hei distributor - i remember seeing somewhere a company that made a small formed sheetmetal piece that you could cutout and rivet into your firewall - i cant seem to find anymore though.
Id like to not fabricate something as I already have a bunch of fabbrication/work to getting this on the road
thanks for any suggestions
blackmopar is offline   Reply With Quote
Old 10-04-2009, 05:04 PM   #2
Sicboy
Sicboy's Avatar
Re: firewall hei dizzy recess
A friend pounded his firewall, about 3/8", to clear the HEI. I did the same, but still waitin on the engine rebuild to be done. Here's a couple pics my buddy sent me:
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline   Reply With Quote
Old 10-04-2009, 06:12 PM   #3
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Didn't have to do a dam thing on my old truck..plenty of space and then some
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-05-2009, 12:00 AM   #4
Captainfab
60-66 Nut
I've never had any clearance issues with an HEI either.
Old 10-05-2009, 12:05 AM   #5
blackmopar
hmmm seems like mine will be tight - but im on the back frame rails perch holes also - maybe ill just move it forward a bit
Old 10-05-2009, 12:08 AM   #6
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
I didn't clearance my firewall either and I am also on the back holes for the mounts. The frame is also Z'd three inches. It is tight, but livable!
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 10-05-2009, 12:14 AM   #7
Captainfab
60-66 Nut
That is the stock location for all V8 engines in the '63-'66 years. If you want to move yours to the forward holes, a set of SB mounts for the '67-'72's will be a bolt in.
Old 10-05-2009, 12:17 AM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Is that Zolatone on the engine compartment - and if so, how did it hold up. Love the color combination.
Old 10-05-2009, 12:28 AM   #9
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
That stuff held up GREAT !! Dropped tools, pressure washer...it held up very well !!
Check out my old build thread for a picture of what I exactly used....you'll be surprised !!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-05-2009, 01:26 AM   #10
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I didn't have to do anything to mine either. I have zolatone in the bed of my truck, and after 10 plus years or about then. it's still holding up. some parts are peeling.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-05-2009, 12:10 PM   #11
blackmopar
thanks captain for the part info - from what all are saying, I shouldnt have to but handy in case I do.
Sean
Old 10-05-2009, 01:24 PM   #12
JRBECK64
I put a GM HEI in my sons truck and didn't have any problems with space. It is a little tight but nothing thats going to cause any problems.
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 10-05-2009, 01:41 PM   #13
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
and if you want to cut your firewall, swing by a target or walmart and look at thier cake pans, one for a pound cake might be just about the right size....
Old 10-05-2009, 03:36 PM   #14
JRBECK64
Now that is one great looking Engine Plant. My hats off to you. Is that the same stuff that a lot of old cars have in the trunk for covering? Did you have to clear coat over it when you were done?
JRBECK64
Old 10-05-2009, 05:47 PM   #15
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I cleared it with a 'satin' clear...but didn't have to....
I actually, liked it better without the clear on it.
I think the 'Rock-a-Chief' is going to get the same treatment.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 12-02-2010, 08:54 PM   #16
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Okay, maybe this was the better thread to post in.
Just started to drop the 350 from the donor 79 into my 66, and the distributor is way too tight against the firewall.
I wonder if the 79 distributor is taller than the ones you guys are using.
66 C20 Service Truck:
Old 12-02-2010, 11:43 PM   #17
BarnFind
As said in earlier posts, I used 67-72 motor stands which moved the motor forward about 2 inches. Not only does this help with HEI clearance but, it also gets the fan closer to the radiator when using a short water pump.
BarnFind is offline   Reply With Quote
Old 12-03-2010, 02:00 AM   #18
blackmopar
barnfind, that is excellent clearance - Ive got mine installed with factory perches in the back slots - it fits but its tight and right now with my dizzy clock position i dont have any further room to spin it ccw (its off a notch so really this shouldnt actually be a problem) but saying to make the point that in oe location an hei is tight as hell on my ride
Old 12-03-2010, 02:14 AM   #19
BarnFind
The 67-72 perches look like the 60-66 but, have a little tighter bend at the bottom where they bolt to the cross member. These are an easy solution and will resolve a couple of issues, not to mention put the engine in the middle of the engine compartment. Sean
Old 12-03-2010, 02:24 AM   #20
LostMy65
LostMy65's Avatar
I see.
I'm guessing those of you who are sliding your motor forward 2" have an auto.
The Manual Trans won't just easily slide forward like the auto tranny.
We would have to move the crossmember that supports the bellhousing.
And then there's also the clutch linkage.
Old 12-03-2010, 10:41 AM   #21
BarnFind
Originally Posted by LostMy65 View Post
I see.
This is true, much more involved for the stick shift guys. Its definitely not a "bolt in and go" modification even for the automatics. Sean
Old 12-03-2010, 03:50 PM   #22
blackmopar
heres a stupid question - why cant you just relocate the 63-66 perches to the forward frame holes and redrill bolt holes in the crossmember?
as my pic shows im up against the wall right now - which means no addtioanl CCw rotation is possibly
other than modifying my exhaust hangers, I dont see what else would be required to do to move forward with an auto (not using oe shift linkage)
Old 12-03-2010, 05:16 PM   #23
astrochimp
If your hei is tight, check your body mounts.
Mine is tight, will turn enough to set timing + a little, PITA to reach that screw that holds cap on.
I was able to remove my distributor for an intake swap.
David
astrochimp is offline   Reply With Quote
Old 12-03-2010, 07:05 PM   #24
777ralph
I've got two of these trucks, both HEI's are tight to the firewall. On the three-onthe-tree truck I "massaged" it with an air hammer enough to swing the distributor. On the 700r4 auto truck it has enough room to move, but only just. If it was a cab mount problem, wouldn't the rest of the sheetmetal fit funky?
Ralph
777ralph is offline   Reply With Quote
Old 12-03-2010, 08:29 PM   #25
Bugeyev8
Bugeyev8's Avatar
just use a small HEI dist...junkyards are full of them
Bugeyev8 is offline   Reply With Quote
