10-04-2009, 05:38 PM | #1 |
Old Heap Driver
Heap Re-Do Part 2, The Motor Swap
I had posted in the original Heap Re-Do thread that future plans called for a 350 GM crate motor. I was literally minutes away from ordering a motor when a friend called me. My buddy said he had something at his shop I may be interested in. I drive down there and he introduced me to a 41,000 mile motor that looked brand new under the valve covers and even better under the TBI intake manifold. We struck a deal and I started the transplant at his shop last saturday. A 700R-4 was already in my garage waiting to be bolted to something. I had it made, lift, welder, Bridgeport Mill, hot tank, and a wall unit slam full of every nut and bolt known to man. Not to mention the salvage yard behind the shop.
I drove the Heap home Thursday night grinning from ear to ear. The only issue so far is with the brand new Weiand intake manifold, has a crack in the casting near the water neck. I called Summit and they shipped a replacement ASAP. I'll get it installed tomorrow night after work. The next couple weeks will be spent detailing out the under hood wiring and plumbing. I finished up the fuel line yesterday. Oh, I forgot to mention, it's a BIG BLOCK!!!!!!!!!!!!!!!!!!!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
10-04-2009, 05:45 PM | #2 |
Re: Heap Re-Do Part 2, The Motor Swap
Great score!
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r http://67-72chevytrucks.com/vboard/s...d.php?t=460030 97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver 220,000 miles, all stock for now |
10-04-2009, 05:51 PM | #3 |
Oh yeah ! Big block power . Can you really tell a difference in the 6 cyl to the bigblock ?
Frank
Born and proudly residing in a Red State ! |
10-04-2009, 06:37 PM | #4 |
I have car A.D.D.
Umm, Does that say 502?
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
10-04-2009, 07:12 PM | #5 | |
Old Heap Driver
Slightly....... LOL Bryan
10-04-2009, 07:12 PM | #6 |
Old Heap Driver
Yes.......but only because I scored the valve covers on eBay....It's a 454.
Bryan
10-04-2009, 07:33 PM | #7 |
Nicely dun
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
10-04-2009, 07:52 PM | #8 |
I have car A.D.D.
Gotcha! Nice work as said. Looks like a lot more fun. You look like this...?
10-04-2009, 07:57 PM | #9 |
It'd be alot cooler if you did
Bryan-
YOU SUCK. later, chuck |
10-04-2009, 09:16 PM | #10 |
67-72 parts collector,…
What size carb are you using?
Also,... Is that a steel fuel line with an "AN style" T fitting? Your truck just got "cool-er",... if that's possible.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-04-2009 at 09:17 PM. |
10-04-2009, 09:23 PM | #11 | |
Old Heap Driver
Holley 670 Street Avenger. I haven't tried tuning it yet. Since the manifold had to be replaced I didn't see and use in getting too detailed with the carb or timing. Steel brake line with a stainless "T" and AN fittings. I kept cracking the stainless line. My flaring skills are very rusty. LOL. Bryan
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. Last edited by S10Fan; 10-04-2009 at 09:24 PM. |
10-04-2009, 09:31 PM | #12 |
Badass
so what are you going to do about the rearend? what is it a 10bolt?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
10-04-2009, 09:34 PM | #13 |
Old Heap Driver
12
10-04-2009, 09:36 PM | #14 |
Badass
oh nevermind then lol
thats should stand up. do you need a diffrent size drive shaft?
10-04-2009, 09:42 PM | #15 | |
Old Heap Driver
I also forgot to add info about the exhaust. My friend's shop where I did all the work also has an exhaust pipe bender. So, we bent up 2.50 inch pipe from the manifolds and out the back through some Magna Flow mufflers I had from another project. Has a really nice mellow sound, until you stomp on it. LOL.
10-04-2009, 09:53 PM | #17 |
Old Heap Driver
Yes I did. I had a back up plan. There's a place about 30 minutes from me that will build a shaft with same day turn around.
Bryan
10-04-2009, 10:01 PM | #18 |
wow!
I second Chucks statement I wanna build something in your buddies place
CHEVY ONLY |
10-05-2009, 10:25 AM | #19 |
You need a flaring tool designed to flare stainless - that's why it's cracking on you. I have one you can borrow. (they aren't cheap)
