Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-15-2009, 09:10 PM   #1
LILRED66
LILRED66's Avatar
ISO/WTB '60-'66 GMC 305 V6 alternator brackets
In Search Of/Want To Buy top & bottom alternator brackets for '60-'66 GMC 305 V6.
LILRED66 is offline   Reply With Quote
Old 10-19-2009, 07:55 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: ISO/WTB '60-'66 GMC 305 V6 alternator brackets
tony, I might have some, my gmc 4000 has a 351, and the alt is on the right side, I will try to get a pic for you to see if they look like the right one...
Old 10-19-2009, 08:04 PM   #3
LILRED66
LILRED66's Avatar
I have checked out several online and all of them had the alternator on the passenger side. The partial brackets I have are on the passenger side, as well, so I am going to go that route.
I need to wire it, once I get it mounted. There are three wires to hook up. The wires are Blue, Black & Red. Any suggestions?
Old 10-19-2009, 08:19 PM   #4
100%Chevy
On my 351,there are only 3 pieces for the alternator mount.
The top adjusting bar and 2 parts that fit together to hold the bottom.
They are the same as a 305's mounts.
If you can't find them,you could probably make the bottom parts.
Mike.
100%Chevy is offline   Reply With Quote
Old 10-20-2009, 12:40 PM   #5
joe231
joe231's Avatar
I have the brackets you need Tony, but they are about an hour away......
what are they worth to you?
CHEVY ONLY
Old 10-21-2009, 07:16 PM   #6
LILRED66
LILRED66's Avatar
An hour...are you still in Norman, OK?
I ended up installing the factory generator and mount, but I want to go with a modern alternator and brackets.
Old 10-21-2009, 08:51 PM   #7
joe231
joe231's Avatar
Yeah I'm in Norman still
I meant the brackets are a hour from me.....
But now that you mention it, they might be generator brackets...
CHEVY ONLY
Old 10-21-2009, 10:26 PM   #8
LILRED66
LILRED66's Avatar
I found the factory generator and brackets, so I installed them and hooked it up like this:
Old 10-22-2009, 07:53 AM   #9
jonzcustomshop
1961 crewcab
tony, I forgot my camera, but my upper bracket is the same as you have, however the lower is huge, the fenderwell is actually notched our from the factory to make room for it, I assume the bracket has provisions for an air pump that might not have been used on my truck. I will still try to get some pics for you, but I don't know if mine will work on your 1/2 ton...
Old 10-22-2009, 08:43 PM   #10
duallyjams
duallyjams's Avatar
I have seen generator converted to a 12v alternator on street rods.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-04-2009, 09:38 PM   #11
100%Chevy
If you want to see a picture of mine,it's on my picturetrail site below.
The album is the one with the pic of my 68 truck.The engine is sitting on the floor in pic 30.Not a good picture,but shows the alternator mounted.There may be other pictures of it in there too.
Mike.
Old 11-04-2009, 09:40 PM   #12
100%Chevy
OOPS!
http://www.picturetrail.com/100chevy
Old 11-05-2009, 08:50 PM   #13
LILRED66
LILRED66's Avatar
Thanks for the information. I got it mounted and wired using the factory mounting brackets and harness. Tim Gehring is the proud new owner.
Old 11-05-2009, 09:14 PM   #14
nbrfd007
nbrfd007's Avatar
Very proud owner!
nbrfd007 is offline   Reply With Quote
