Old 10-21-2009, 07:52 PM   #1
bitchin85
bitchin85's Avatar
engine identification
i just picked up this 350. can someone tell me what its out of and if its crap or not? its a two bolt i know, the vin is 3970010 and the the number on the front passenger side under the head is v0129tkb thanks guys. i was told its an "M" block and thats a good thing but im not really sure..
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 10-21-2009, 08:17 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: engine identification
1976 350 4BBL truck engine 165 HP
http://www.nastyz28.com/gm-chevy-cod...s-suffix-8.php
ont_guy_38 is offline   Reply With Quote
Old 10-21-2009, 08:25 PM   #3
bitchin85
bitchin85's Avatar
what doesthe L LS9 mean? i know it has M on the block not L
Old 10-22-2009, 09:01 AM   #4
68 TT
Still plays with trucks
68 TT's Avatar
The LS9 is an option code and the M is a casting identification mark used by the foundry.
A 2-bolt block with main studs is quite strong so it is not junk. It is a good foundation to build on.
68 TT is offline   Reply With Quote
Old 10-22-2009, 09:43 AM   #5
ironroad9c1
Master Hater
use to be a myth around that all 010 blocks where high nickle blocks, I think that was disproved a few years ago.
ironroad9c1 is offline   Reply With Quote
Old 10-23-2009, 11:57 PM   #6
bitchin85
bitchin85's Avatar
so how do i know if its a high nickel block
Old 10-24-2009, 12:48 AM   #7
pcwillsie
there will be a casting there also. I have been thinking about who told me all this. It was an old man that has had a machine shop for ever and a day. just like there are better metal in cranks there were better metal in some blocks. He told me about this about ten years ago when I tool a block into him to get it machined. I wrote this stuff down somewhere but I thing it is at my office. If I cant find it i will give him a call monday and get the info from him again.
pcwillsie is offline   Reply With Quote
Old 10-24-2009, 01:28 AM   #8
cableguy0
010 020 under the timing cover is high nickel block
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-24-2009, 01:31 AM   #9
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
That's correct, the 10 20 indicates the nickel and tin percentages
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-24-2009, 01:42 AM   #10
ghettoluxury
ghettoluxury's Avatar
remember a 2 bolt can be turned into a 4 bolt
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-24-2009, 01:57 AM   #11
nechevy
nechevy's Avatar
Actually the 10 would mean the there was 1% more tin to help the metal flow into the cast and the 20 means 2% more nickel was used to make it stronger and it is in the front and rear of the blocks. HIGHLY desired
What would foose do?
nechevy is offline   Reply With Quote
Old 10-24-2009, 10:11 AM   #12
68 TT
68 TT's Avatar
Any idea what vintages the high nickel block was made?
Old 10-24-2009, 02:29 PM   #13
bitchin85
bitchin85's Avatar
ok i just checked out my block ana it said 010 but directly under that is has 020 then 501 and on the other side it says G18 512 532
anyone know what any of this means?!?
Old 10-24-2009, 02:31 PM   #14
cableguy0
010 020 is high tin high nickel. its a good base for a performance build. the block is a bit sturdier
Old 10-24-2009, 02:37 PM   #15
bitchin85
bitchin85's Avatar
anybody have an idea what it came out of?
