Old 10-23-2009, 01:43 PM   #1
3r!c84
Badass
3r!c84's Avatar
Exclamation drop spindle help!
hey i just got some 3in djm drop spindles and im running into the problems
the brake line off of the caliper runs into the upper balljoint nut.
so i cant put on the caliper?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-23-2009, 02:06 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: drop spindle help!
i tryed lossing up the brake line and moving it down but it wont let me move it down only in that one possession
anyone?
-00 Saturn 5spd
1/4:13:90
Old 10-23-2009, 03:56 PM   #3
umbra
I cant remember what I did when I installed the DJM spindes on my 82. When I get home I will check and take some pics of them. What side are you working on?
umbra is offline   Reply With Quote
Old 10-23-2009, 04:10 PM   #4
3r!c84
Badass
3r!c84's Avatar
drivers,but its going to have the same problem on the pass.
thanks
-00 Saturn 5spd
1/4:13:90
Old 10-23-2009, 04:15 PM   #5
3r!c84
Badass
3r!c84's Avatar
look.you can see in the last pic,how it wont push up
-00 Saturn 5spd
1/4:13:90
Old 10-23-2009, 04:48 PM   #6
70k52wd
Blaze-Air
70k52wd's Avatar
You need to gently bend the brake line to fit.
70k52wd is offline   Reply With Quote
Old 10-23-2009, 06:41 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
x2.
You need to "tweak" the steel line away from the upper ball joint.
Keith
Convert to disc brakes.
Old 10-23-2009, 06:59 PM   #8
3r!c84
Badass
3r!c84's Avatar
a friend came over and did that.thanks for the help
the fronts done
-00 Saturn 5spd
1/4:13:90
Old 10-23-2009, 11:25 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
I usually slip a crescent wrench over the line long ways so it doesn't try to kink. Gently lean it out of the way and your good to go.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-24-2009, 01:48 AM   #10
menace121978
menace121978's Avatar
if its done where's the pics!?!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 10-24-2009, 11:00 AM   #11
3r!c84
Badass
3r!c84's Avatar
im starting a new thread when its done,WITH PICS ,i got the back left and some more grinding on the front.
-00 Saturn 5spd
1/4:13:90
Old 10-24-2009, 11:19 AM   #12
menace121978
"Dennis the Menace"
Old 10-24-2009, 03:18 PM   #13
3r!c84
Badass
3r!c84's Avatar
ok im back...
the rivits on the rear bumpstops are kicking my ass.
i cut the heads off the rivits and its still not moving
-00 Saturn 5spd
1/4:13:90
Old 10-24-2009, 06:41 PM   #14
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
I agree here, and wish the sellers stated that more.
I did my 1982 GMC Dually many years ago and ran into the very same issue.
Most importantly, as I have seen you have already accomplished this...
Is to support that metal end of you brake line's tube; and by all means support that tube when you are bending it!
A tube can collapse if you place too much pressure at that point and incorrectly bend it.
Be careful when doing this!!!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 10-24-2009, 07:49 PM   #15
lolife99
lolife99's Avatar
Originally Posted by 3r!c84 View Post
ok im back...
Grind the rivet flush with the bracket,... then take a prybar, and pry the bracket off the frame.
I use an air chisel to push the leftover rivet thru the frame.
Keith
Old 10-24-2009, 08:18 PM   #16
3r!c84
Badass
3r!c84's Avatar
i cut a x in the head and then air hammerd the heads off,thats as far as i got on the rivets
-00 Saturn 5spd
1/4:13:90
Old 10-25-2009, 07:25 PM   #17
3r!c84
Badass
3r!c84's Avatar
update!!! back drop is done...went to go take it on a test drive,and the front tire is rubing the spidle again,going to grind it down some more tomorrow,
but the back reallyy droped down,the back looks a little lower then the front,but i took a level and it is sitting level
-00 Saturn 5spd
1/4:13:90
Old 10-25-2009, 08:32 PM   #18
lolife99
lolife99's Avatar
It the wheel hitting the spindle, caliper, or a-arm?
Check all three places.
Keith
Old 10-25-2009, 08:40 PM   #19
3r!c84
Badass
3r!c84's Avatar
sorry its only the spindle,the top part that holes the brake caliper is hitting,i was grinding on it a few days ago,but i guess i needa take more off
-00 Saturn 5spd
1/4:13:90
