Old 10-23-2009, 02:20 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
HEI issues
hey all..
so here's the backround before the issue
started as;
83 4x4 with a 305 with electronic spark control
NOW has a 350 (with the same distrubitor)
ive always had issues keeping good spark
but now after finishing my project i went to start it and i got it to run for 10 seconds...
and NOW i have NO spark......
coil tested bad.. replaced coil.. replaced card (in distro)
still no spark...
sooo it leads me to believe it's the ECM because everythign is testing out correctly...
so i ordered the "correct" distro a new billet HEI without the plug for the ECM
with vaccum advance
now my concern is when that electronic spark control remains disconnected what will be effected by that? do i have to worry about gauges etc not working?
i know i dont need it to run the 350 (plus it's builtup so screw emissions)
but im worried abou the internals...
any wiring i have to change/worry about? anything going to not work?
or does that stupid little brain box effect anything else in the truck at all?
thanks!
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 10-23-2009, 03:09 PM   #2
Jonboy
Slots go on anything!
Re: HEI issues
http://www.73-87.com/7387garage/drivetrain/escrepl.htm
Try that.
Old 10-23-2009, 07:00 PM   #3
68 TT
Still plays with trucks
68 TT's Avatar
Re: HEI issues
Are you still running the CCC Q-Jet?
68 TT is offline   Reply With Quote
Old 10-23-2009, 07:03 PM   #4
68 TT
68 TT's Avatar
Re: HEI issues
I don't think any of the gauges in the 83 were controlled through the ECM so removing it should not effect anything other than maybe EGR or canister purge.
Old 10-23-2009, 09:12 PM   #5
cjracing15
cjracing15's Avatar
Re: HEI issues
This is what I have done in the past. I rebuilt my dist with 1978 parts from the part store. All you have to do is remove the dizzy disasamble and replace the pick up coil and the module. Discontinue the esc plug and just put the original wires for the coil back on. It will work fine and it is about the same money for both coil and moduel for the earlier model as what you are going to pay for the esc module alone. I have done a bunch of them for myself and freinds alike.
But since you have already ordered a new hei all you have to do is unplug the esc and install the new dist. Plug the vac advance and set the timing. You will be much happier in my opinon.
The fleet
94 Chevy 4x4 reg cab
2018 Traverse (wifes car)
1977 SWB stepside
1949 Chevy truck
cjracing15 is offline   Reply With Quote
Old 10-24-2009, 09:17 AM   #6
Desert1957
Desert1957's Avatar
Re: HEI issues
I need more info on your truck...
I will tell you I owned a 1983 Chevy G20 Van with this setup. It started having issues with "No starts" . I just installed an earlier stock style HEI with a vacum advance.
But FYI my 305 did NOT have an O2 sensor or a feedback Carb w/ solenoid.
If your engine has a full "Computer Comand Control" setup it will not be the same swap. If you are unsure what I'm talking about , PM me so I can discuss more details....
Desert
Desert1957 is offline   Reply With Quote
Old 10-24-2009, 12:02 PM   #7
dammitmitchell
the pollock
Re: HEI issues
hey gents
well i was away from the internet all day involuntarily so i got out the books and chased the wires, the only two wires that left the "brain" and ontacted anything else was the positive that plugged into the HEI with the fuzeable link.
and a blue wire that goes to the firewall fuze block.
and i have not a clue what the blue wire does
well it's "pigtailed" and out of the way ive allready made a plug for the gaping hole in my firewall now
and the motor im running is
350 bored .40 over with a noticibly large cam
highrise spacerplate and 670 holley..
heads have been reworked etc...
so stock qjet hells NO.. =-)
thanks for the input gents..
Army vet 02-08
Old 10-24-2009, 12:05 PM   #8
cjracing15
cjracing15's Avatar
Re: HEI issues
With that motor and carb drop that dizzy in there and fire it up and drive it.
The fleet
1977 SWB stepside
1949 Chevy truck
Old 10-24-2009, 12:06 PM   #9
dammitmitchell
the pollock
Re: HEI issues
sweet i also found the blue wire swwweeeeettt..
problem solved thanks guys!
Army vet 02-08
