Old 12-25-2009, 02:43 PM   #1
hoplias
87 silverado dual gas tank problem
I recently bought a 87 1500 sivlerado and its a really cool truck and I am going through fixing the few things wrong .The question is the dual gas tanks .It only works when on right tank and if I switch it to left it will not run .What is my best plans of fixing the problem .Is it most likely the switch or what ?
hoplias is offline   Reply With Quote
Old 12-25-2009, 05:30 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: 87 silverado dual gas tank problem
check the power to the sides through the switch then if you have power there check to the fuel pump in the tank... i assume its the electric fuel pump with an EFI motor
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-25-2009, 05:36 PM   #3
Malo83
Cruzzzn' Vet
Malo83's Avatar
Had the same problem, replaced the switch and it works as advertised
Malo83 is offline   Reply With Quote
Old 12-25-2009, 06:58 PM   #4
nlped
nlped's Avatar
I had the same problem with "Bob", but the PO didn't worry about it and left half a tank of gas in it...for a LONG time. So I had to buy a new tank, pump, fuel level sending unit and the only part that was actually bad...the switch in the dash. I bought all of the parts from Rock Auto. I would tell you to replace the switch with a AC Delco switch not some no name one. It was only about $10 shipped to my house from them.
Good Luck, and you will love that truck.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 12-25-2009, 08:17 PM   #5
hoplias
Thanks guys .Should the guage still change if its the switch cause when I change the switch over the guage does not change either .I will try the switch first cause it does seem too loose so I am hoping its just that .
Old 12-25-2009, 08:25 PM   #6
nlped
nlped's Avatar
My guage didn't change either. It does now
Carter
Old 12-26-2009, 10:23 PM   #7
hoplias
what is best way to get the switch off properly ?
Old 12-27-2009, 04:48 AM   #8
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
It just snaps into place in the dash. If you want to remove it with the least amount of damage to it or the dash you'll have to gain access to the back side of it by one of 3 methods.
1. Reach up under the dash while laying on the seat and push up & out on the bottom of the switch. Then reach up to the top of the switch and push down & out.
2. Remove dash bezel & dash pad. If'n ya have a/c, move the center duct out of the way and reach into the back side of the dash to squeeze the top & bottom together and push the switch out.
3. Remove the bezel remove the radio reach inside and pop it loose from there.
While #1 is the simpler one, if'n yer a big guy with big hands & armsit can be a real P*I*T*A
Personally I prefer going after it as described in #2.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-05-2010, 09:48 PM   #9
hoplias
Well I changed the switch and it still does not work .
What is next best thing to check ?
Old 01-05-2010, 10:20 PM   #10
Chlsnk
Chlsnk's Avatar
Check your grounds mine has the copper ground strap snapped.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 01-05-2010, 10:31 PM   #11
hoplias
not to sound ignorant but where should i look for the ground wire
Old 01-06-2010, 12:39 PM   #12
hatzie
Moderator
hatzie's Avatar
If it's the same as the `85 trucks it should attach to the ring on top of the tank around the sender.
Old 01-06-2010, 02:24 PM   #13
nlped
nlped's Avatar
^^^Hatzie is right, and it's a bit$h to get to. I actually had to drop the tank to check mine. While I had it out I put power and ground to the pump to see if it was working...it wasn't.
Carter
Old 01-06-2010, 10:30 PM   #14
jdclemons
I can join the club. My driver side tank work and when i throw the switch to the pass, the fuse blows. Any pointers.
jdclemons is offline   Reply With Quote
Old 01-07-2010, 05:02 AM   #15
hoplias
I am going to wait till I get new fuel pump cause I do nt want to drop it twice .I might as well cahnge everything it might be cause this has always been a issue and I want it fixed once and for all.
The switch blowing problem was on mine abreaks in wires and when switched they would arc .I suggest you check the wires cause I bet that what it is .
Old 05-07-2010, 11:35 PM   #16
shloopter
I had the same problem. I had the bed off so I put power to the pump right at the tank and it turned on. After diagnosing the problem, it ended up that the cross over valve was bad. It sits right next to the right tank. The cost is about $95 for the part.
shloopter is offline   Reply With Quote
Old 05-07-2010, 11:38 PM   #17
shloopter
Now for my new tank switch problem. As I stated in an eariler post, both tanks are working great now. Problem is, when you switch tanks with the engine running, if you happen to only move the switch half way, it shuts the engine right off. Then switch it up or down it fires back up. Is this a bad switch? Is this switch hooked to some kind of engine cutoff?
Old 05-08-2010, 12:28 PM   #18
foamypirate
foamypirate's Avatar
If the switch is in-between positions, then neither fuel pump is getting power, so your engine is starved for fuel and shuts off.
foamypirate is offline   Reply With Quote
Old 05-08-2010, 02:35 PM   #19
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yea my daughter get in and sometimes she bumps the switch and it just cranks. Thats the first thing I look at "did she hit the switch" and evertime the switch is sittin in the middle.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 10-28-2015, 07:46 PM   #20
weider1717
nvm
weider1717 is offline   Reply With Quote
