Old 02-07-2010, 08:02 PM   #1
melvin
Pinion bearing question
Hey guys -
I'm planning on swapping in an eaton posi in the rear of my 70 c10 project. Everything is still tight, ring/pinion are in great shape, backlash is at 0.007, etc.
My question is, if I want to replace the pinion bearings at the same time is it as simple as replacing the bearings, reusing the existing shims, and preloading to factory specs?
melvin is offline   Reply With Quote
Old 02-07-2010, 08:23 PM   #2
zzzjojozzz
zzzjojozzz's Avatar
Re: Pinion bearing question
other then pressing the bearing off after u get the pinion out i wood recomend using the existing crush washer also
zzzjojozzz is offline   Reply With Quote
Old 02-07-2010, 09:03 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Start with the original shims and go from there. I would use the original crush sleeve only to check prior to final button up then use a new one or a solid sleeve that you shim to fit.
dwcsr is offline   Reply With Quote
Old 02-07-2010, 11:30 PM   #4
69GMCor70Chevy
69GMCor70Chevy's Avatar
When I did mine this fall I re-used all of the shims but changed the crush collar. All is good!
68 Camaro - 327 Original Red on Red Car
69 GMC LWB - Built 350 a Blast To Drive
69 GMC LWB - "Green Machine" One Family Truck
70 Mercury Marauder - Future Project
69GMCor70Chevy is offline   Reply With Quote
Old 02-08-2010, 02:10 AM   #5
69 longhorn
If you are not changing gears, I would replace the bearings/races on the pinion(yes do keep the original shim that was under the rear pinion bearing). replace the crush collar, & the pinion seal. Pull the nut up on the pinion (use lock-tite), till you crush it enough to get the proper rotating tork, with motor oil on the bearings. Check the book, but in the range of 15-20 Inches rotating(not break away tork) , should be good on NEW bearings. When you plant the ring gear on the new carrier be carefull to seat her flat,(check for burrs , ect) & check the backlash in 4 points to be sure the ring is running straight when you assemble. If you use the same side shims, you should be ok with the new carrier.....unless you notice a change in the backlash. At that point, you need to add/subtract from side to side to compensate. if you notice a spot in the backlash a tad tighter , while checking in the 4 spots(say .0015-.002), you should be able to live with that(assuming .007-.008 backlash). hope that helps, crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 02-08-2010, 12:01 PM   #6
melvin
Thanks guys, that's what I wanted to hear.
1970 c10 swb fleetside. Frame off, 2.5/4" drop, LS1/4L60e, daily driver.
Old 02-08-2010, 05:06 PM   #7
Wrenchbender Ret
Ive rebuilt many of them but if everything is snug & feels good I would leave it alone. You will want to replace the seals. Mark the position of the pinion nut before you pull it & put it back the way it was with some locktight.
Wrenchbender Ret is offline   Reply With Quote
