Who needs sleep...
![]() Join Date: Aug 2009
250 or 327... help me decide please.
Ok, so I'm planning out a motor project for this summer (because I enjoy spending the day in 110" shops with 100% humidity in FL summers
![]() Let me preface this with - the original 307 is in my 72 and runs just OK, smokes and is a little soft. I am planning to rebuild it at some point, if even to only have on hand. So, I was offered a 67 327, the block is machined and ready to go at 30 over (though I'll give it a once through) and the doublehump heads will need to be worked over, they're not done, though are present. Included is a new set of pistons and a rebuild kit. OR do I pick up a 67 250 - guaranteed rebuildable - from the junkyard. I'm seriously torn here, the initial outlay differs by only a couple hundred bucks, both will likely need $3-400 in machining and another couple hundred in parts. Can you throw some serious opinions at me about this? I had a 250 in my 68 and loved it, and the nostalgia plays in a bit (plus a general love for stovebolts) but the 327 sounds like a hot deal. I already have the 4bbl carb and manifold for it, was possibly going to put it on the 307. Trip |
The Older Generation
Re: 250 or 327... help me decide please.
-I'm in the process of building a 327, hopefully with Vortec heads. I'm putting on my fireproof underwear here but if I was going to spend the money on a inline it would be a 292 not a 250...
Just my 2¢ worth... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-08-2010 at 11:46 AM. |
Who needs sleep...
One thing I forgot to add... I'm no teenager, but not quite an old graybeard yet either. I like to romp on the gas a bit occassionally, but 'go really fast' and 'burnin' up tires' don't really factor in as much as they used to.
Trip |
Member #1049
I would stick with the 327 because it will bolt right in.. no need to find and change things like exhaust, motor mount towers, oil pressure lines and throttle linkage
i have a low miles 250 thatz .030 over.... i will put on you for decent money...
but, i like the 327.
It seems most everyone prefers the 327. I love how some of these 6-cyl look, I think it's cool to do something a little different.
It you haven't seen it yet........this thread is great for some under the hood inspiration!! http://67-72chevytrucks.com/vboard/s...d.php?t=378111
GROVE STREET CUSTOMS est. 2005 ![]() 67' C10 LWB/350/T400 69' C10 SWB/454/T400 71' C10 LWB/383/ 72' C10 SWB/350/T350 15' Crew Silverado/6.2 Last edited by MESS-HALL; 02-08-2010 at 12:00 PM. |
I'd say 327. You can use all the brackets off your 307. If your truck is an automatic & you have the 3.07 rear end it may be a little tall for the 250.
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 02-08-2010 at 12:24 PM. |
Who needs sleep...
Truck WAS a 3 spd standard, will be going back to a 4 speed Saginaw, though right now with the TH350 I'm in 3rd before I'm through a light... I need to find out what rear is in it, haven't ruled out swapping it out yet.
Good point on the brackets... add that to the expense column for the 250. Trip |
#9 | ||
"I ain't nobody, dork."
No brainer... V-8...
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
HickTown
I'd go out of the norm and go with the 250!!!!
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ Last edited by culp7; 02-08-2010 at 04:54 PM. |
Big Red - Now its a SWB!
I say 327, it'll drop right in and I'd rather have a v-8 anyday. I had a 305 v-6 and a 351 v6 before (those are more rare than the I6) and I have no regrets dropping in the 350 small block.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 02-08-2010 at 06:50 PM. |
You know this decision really goes right back to what do you want?? I personally like them all also. If you can find a 6 banger with all the ness. brackets and such. For the same amount as the 327. more power to ya to go that route.
If not, i would stick with the 327 for ease of installation. I would definitely check to see what gear ratio you have out back. May be to low for any good runner, I personally like a mid 3's ratio 3:42 3:55, but most of these trucks came with 3:08 or 3:73's.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
#13 |
I am a Referee of life.
The 327 will be way cheaper but the 6 with a few bolt ons will be way cooler.Performance will be some better with the 327 but fuel milage should be about the same either way.Kinda depends on what "YOUR" cool factor is.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#14 |
Is your cool factor this high??? It's the GM L6 off road racing six!
#15 | |
it really is up to what suites your needs if you want some power and speed then go with the 327 if you just want to cruise and have an cool factor then go with the i6 i personally like the idea of both
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#16 |
I chose Both...
327 in the 68 Sounds Great 250 in the 71 Six Bangers are Super...... Smooooth!
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 02-08-2010 at 10:28 PM. |
#17 |
i have a 6 banger now, after six month of searchin the bracket to make it power sterring, i would go with the v8. i am in search of one now!
#18 |
I have a 250 PS setup if you need one?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
#19 |
![]() Join Date: Sep 2003
Vote 327 easier considering truck is already V8. and you may be convinced after trying to find all the brackets you might need for the I6. P/S brackets are fun to find these days.
#20 |
HickTown
EDIT: Please refer to the rules on WTB's. Want to buy items are only allowed for paid subscribers.
1993 Ford Mustang Vert w/ 2.3 1969 Chevy C/10 w/350 1968 Chevy C-20 w/250 1976 Dodge Aspen W/ 225 2000 Toyota Tundra w/4.7 1987 Dodge Ram D-100 w/360 255/70-15 ___________ (oo)══╬══(oo) ‾‾‾‾‾‾‾‾‾‾‾ Last edited by msgross; 02-10-2010 at 03:13 PM. Reason: WTB |
#21 |
the boat guy
coulda had a v-8.
ive seen some really cool inline 6's and ive seen a couple 300+hp i-6's but nothing sounds like a v-8. i could listen to a camed v-8 idle all day.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#22 |
If I were going with a 6 I'd go 292, certainly.
Getting good fuel/air distribution means multiple carbs or FI on a six, whereas a single four barrel does great on a V-8. You are also going to want more gears than stock-a 4 speed auto or 5 speed manual-with a six. GM, Ford and Mopar built a LOT of V-8s for several very good reasons. The sixes never lived up to their potential in stock trim for those same reasons. All those furrin inline "motors" had multiple SUs or Webers or the cranky mechanical FI. Detroit gave up on multiple carb inlines around the time Marilyn Monroe married DiMaggio because Americans wouldn't synchronize carbs and put up with a mess of fuel lines. But you know, a well set up six sounds great, whether a pushrod GM or /6 Mopar or a DOHC Jag or Alfa. If the bother doesn't bother you, be different. |
#23 |
#24 |
Drop a V-16 in there. All the power you need and then some...
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS ![]() -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) ![]() You've gotta be able to stop and steer before you can go fast! |
#25 |
Inline six with Offy intake 3 one barrel carbs with chrome dress up kit and machine head to achieve 9.5-1 compression combine with 4 speed and a 3.73 rearend and you have a nice
