Old 02-09-2010, 01:48 PM   #1
71C10SWB
71C10SWB's Avatar
Exclamation Any tips on installing vent window rubber?
I bought new vent window rubber for my '71.
Last night i started on one of them. It took me quite a while to get both sides of the "foot" down in the channel. I sprayed some silicone down in around everything and I still had a lot of trouble.
I still don't think i got it down in the front corner like it should be.
Is there some sort of trick to this or is it just going to be a pain?
71C10SWB is offline   Reply With Quote
Old 02-09-2010, 01:59 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Any tips on installing vent window rubber?
subscribe, Ill be doing this too
1967custom
michael bustamante is offline   Reply With Quote
Old 02-09-2010, 02:05 PM   #3
mikemileski
Try this.
http://67-72chevytrucks.com/vboard/s...d.php?t=153937
Mike Mileski
Tucson, AZ
mikemileski is offline   Reply With Quote
Old 02-09-2010, 05:11 PM   #4
classic70
classic70's Avatar
I had the same problem so i slightly pryed the channel apart so it would go in slightly easier and in the sharp corner i cut some of the rubber off so it would go in. It may not be the right way but that is how i did mine and the rubber is in there good and tight and i crimped the channel back some. hope that helps
classic70 is offline   Reply With Quote
Old 02-09-2010, 06:56 PM   #5
48richard
48richard's Avatar
I just did this. I had to take the frame apart and rivet it together again . When I put the new rubber in I used dish soap as a lubricant. It's very slippery, and then washes off easily.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 02-09-2010, 07:20 PM   #6
mbgmike
Here is a revit tool we sell and also rent to install the revits
http://www.bumpandgrindgarage.com/New_Listings.html
Its a bit pricey to do just a couple windows thats why we rent it also.
This is the best tool made to install the revits quick
We sell the revits and setting tape as well.
mbgmike is offline   Reply With Quote
