02-17-2010, 09:28 PM | #1 |
1962 GMC Engine Size
I just recently picked up a 62 GMC with the V-6 in it, im guessing its the 305. Is there anyway to positively id it? Thanks for the help
02-17-2010, 09:34 PM | #2 |
1961 crewcab
Re: 1962 GMC Engine Size
check out this site for all the gmc info!
http://www.6066gmcguy.org/
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-17-2010, 09:37 PM | #3 |
1961 crewcab
please tell me it wasn't this one:
02-17-2010, 09:41 PM | #4 |
yeah thats it........
02-17-2010, 09:42 PM | #5 |
I listed it on there, are you Jon that wants it??
02-17-2010, 09:53 PM | #6 |
1961 crewcab
yeah... I've been wanting a palimino tan gmc ever since I saw the one imperial custom did...
02-17-2010, 10:04 PM | #7 |
Cool.... I was just making sure it had the 305 in it so I wasn't lying to anybody. It is a very different color I've only seen one like it before and I've had alot of these trucks (not GMC's though). Check your email.
02-17-2010, 10:22 PM | #8 |
Ironhill:
To identify your V6, look in front of the passengers' side valve cover (ie. behind the alternator). You should see an engine number there followed by a letter, then a serial number. It is very likely a 305 if it is the original engine, but those first three numbers on the block should tell you definitively. The letter after the number indicates the series of 305's. GMC had series A through E in different applications. Yours is likely a series E if it is original. Regards, Steve New Orleans |
02-17-2010, 10:36 PM | #9 |
Thanks for the help Steve!!
