Old 02-04-2003, 08:49 PM   #1
68gmcjon
Got earplugs?
68gmcjon's Avatar
Glasspacks
If i have mufflers that just clamp on to my pipe couldn't i unclamp them and put in glass packs that are relatively the same size? or will i have to cut?
1968 GMC
Original A/C, bucket seats, PS,PB
396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression
Alltogether 411HP and 446ft/lbs
Dana 60 w/ 3.54 gears
Turbo 400 tranny
Why would you have anything other than a big block? HAHA
68gmcjon is offline   Reply With Quote
Old 02-04-2003, 08:52 PM   #2
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
You sould just be able to clamp the glass packs in so long as they are the same length and diameter as your old one. However glasspacks tend to be longer that your usual muffler.
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 02-04-2003, 09:15 PM   #3
68gmcjon
Got earplugs?
68gmcjon's Avatar
I know they do tend to be longer. Which are better the longer or shorter glasspacks, or is there a change in sound?
1968 GMC
Turbo 400 tranny
Old 02-04-2003, 09:30 PM   #4
MU72
MU72's Avatar
Longer glasspacks are quieter and more mellow. The shorter ones are louder and more aggressive. If you don't want it to be too loud you should go with 18 or 24 inchers. Or you could do like I did and go all out with 12 inchers. Sounds great
72 Cheyenne 1/2T LWB
original ochre/white
09 Silverado ECSB
76 International ScoutII
MU72 is offline   Reply With Quote
Old 02-04-2003, 09:56 PM   #5
68gmcjon
Got earplugs?
68gmcjon's Avatar
Barn or anyone in the SC kansas area know where i can get some cheeeep glass packs?
1968 GMC
Turbo 400 tranny
Old 02-04-2003, 10:04 PM   #6
71Seth
71Seth's Avatar
I have 12" pacs on my 71. Truck sounds very very good. Really gets attention comming out of a curve and down a stright away, or just good ole roasting of the tires. But then again i would run open headers if I could!!!!!! :-)
97 ext cab 4x4
04 pontiac grand am
05 honda rancher AT (yellow)
71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter
71Seth is offline   Reply With Quote
Old 02-04-2003, 10:47 PM   #7
casey
casey's Avatar
Changing your mufflers really depends on weather they welded those b@tchs on or not , thats a little trick those muffler shops like to play, welding mufflers on, they never did that from the factory, and you used to be able to change mufflers no problem.And as far as glasspacs go you can use any straight through muffler and get great sound, theres some real cheapes out there that will work great for playin the pipes, don't pay for the name.
casey is offline   Reply With Quote
Old 02-07-2003, 02:52 AM   #8
benwantland
http://www.racerpartswholesale.com/tbolt1.htm I got 2 12" glasspacks from these guys for $25 shipped for my Ford. Of course, they use a louvered core, which makes them a little quieter and also slightly more restrictive, but I just needed cheap mufflers. You can get Dynomax glasspacks at Advance Auto or from www.summitracing.com for under $20 each. They are my favorite becuause they have smooth cores and also are availible in a lot of different configurations.
benwantland is offline   Reply With Quote
Old 02-07-2003, 05:05 PM   #9
Oborny71
Oborny71's Avatar
like mentioned earlier, some muffler shops weld you mufflers on. Any good muffler shop will only clamp them on so that they can be easily changed, and you don't weld every thing because your exhaust system needs to be able to take a little bit of "twist" in it. If you weld everything your chances of blowing exhaust gaskets is greater. Just some of my previous experiances
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 02-07-2003, 05:29 PM   #10
HotRod929
HotRod929's Avatar
What would the sound difference be b/w a 26" glasspack and an 18" glass pack? Would it be very noticable? Thanks
HotRod
1970 Chevy C-20
350 V-8
New Additions:
Summit Headers
135amp alternator
Proform HEI
Sunpro Tach
Powr-Loc POSI
MSD 6A Ignition Box
AIM: HotRod929
Old 02-07-2003, 06:10 PM   #11
crazy longhorn
Fabricate till you "puke"
I think there are a lot of "myths" about welded exhaust! I worked in a muff shop for about a yr, & we didnt weld eveything.....or weld things to get a repeat customer over parts he couldnt change. A lot of guys would request a welded system (yes sir!), & some would say "I dont want anything welded" (again, yes sir!). Personally, I prefer a welded system & my longhorn is welded. As far as taking a welded system apart......no problem, I have a torch! the system on my longhorn was done on the floor in my garage, & has a welded H pipe,muffs, & tailpipes. ...it hasnt caused any problems. I have a straight run from the headers to the muffs(a 3 degree kink in the pass side to make line with the collector), & 2 notched crossmembers(1 custom from scratch). thje 3" tail pipes are mandrel bent, & exit ahead of the rear wheels.....yes it loud! As far as glass pcks, I dont like them.... but if you run them the longer ones are a lot more mellow......& stick them as far to the rear as you can , or the heat will burn the packing out......then you might as well have saved the cash & just ran pipe. Good luck.....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
