Old 03-23-2010, 10:23 PM   #1
BigBlockBurris
BigBlockBurris's Avatar
Flywheel question
I need some help. I am fixing to swap motors in a 1968 GMC with a four speed (SM-420). I am installing a one-piece rear main seal 350. So heres the question. What flywheel do I use for the one piece rear main seal motor, but with the mechanical clutch linkage. All factory one-piece rear main seal straight drives were hydraulic clutch.
Thanks!
BBB
BigBlockBurris is offline   Reply With Quote
Old 03-23-2010, 10:34 PM   #2
Schwinn68
Schwinn68's Avatar
Re: Flywheel question
subscribing.............
I've got the same question but in reverse. I'm swapping a 91 5speed trans with an original 350 in.
Ben
_____________________________________
1971 Chevy shortbed 350/4-speed sold
2005 Chevy Duramax EC/4x4
Local 597 Pipefitters
certified TIG MIG and stick welder
Schwinn68 is offline   Reply With Quote
Old 03-24-2010, 08:31 AM   #3
hchad18
hchad18's Avatar
I would think you would just install a flywheel for the newer post 86 small block. I don't think the clutch linkage, hydraulic or mechanical would affect it.
hchad18 is offline   Reply With Quote
Old 03-24-2010, 04:38 PM   #4
Wrenchbender Ret
I agree with Mr.18.
Wrenchbender Ret is offline   Reply With Quote
