Old 02-05-2003, 10:30 PM   #1
71Derelict
seatbelts
I am looking for some 3 point safety belts to put in my cab. There are none in there currently. I found some for about 65 dollars each. This seems pretty steep for a seat belt. Anyone know of where I can find some at a cheaper price. Or someone know of a rig I can possibly get them from out of a wrecking yard that will bolt in easily. Thanks.
shawn
71 C/10 Short Wide
2/3 drop, 383/350/3.08 posi
in various states of repair
growing into 4/5 drop 383/700R4
71Derelict is offline   Reply With Quote
Old 02-05-2003, 11:14 PM   #2
I got mine when I got a new (used) seat. They came out of a 90 Chevy 1500. I paid $25 for the 3 point belts and center belt. The bottom retractors will have to be mounted a bit differently than stock, but thy work good. If you want to see a little better check my web link in the signature and see how I hooked them up.
Old 02-06-2003, 03:36 AM   #3
Duallie
Duallie's Avatar
I agree. I just put '98 Suburban front seatbelts in my C30. I had to redrill the floor for the retractor, and I was amazed at how well it all fits and looks. The only problem was the recycler wanted $80 a side. And then I found aftermarket belts for $73, plus shipping...............to Alaska................hmmmmmmm, thats not so bad after all.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 02-06-2003, 04:16 AM   #4
Ed ke6bnl
Re: seatbelts
shawn
We got word on the site to use S-10 and we found some for sale that day for 15 dollars and the passenger is a direct bolt in and the driver side we made a heavy metal bar to move it over a couple of inches but nearly a bolt in. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 02-06-2003, 02:50 PM   #5
mt Al
I just put two sets into my suburban. Years ago I put a set into my pickup.
I bought my pickup belts new for $85 per side plus mounting plates from www.julianos.com for $15 a pair. They work and look great, no regrets. If you are planning on keeping your truck for a long time I highly recommend buying new stuff.
Went to www.car-parts.com for my suburban 3 points. Searched for seat belts from newer Chevy pickups, got a LONG list and broadcast a request for color, condition and price. A few days later I had a long list of replies and, like an idiot, went for the lowest price in the color I wanted. Paid $60 plus shipping for the pair (not including the mounting plates from julianos, A MUST!). They work fine and look OK, but are not suitable for a first class job. The housing that sits on the floor rides a bit high and is way too large compared to the new ones. The webbing is stained, the plastic parts that cover the top anchor are cracked and/or missing. Again, they work, but they aren't the right thing if you want a really nice looking truck in the end.
If you are getting 3 points for safey and don't properly mount them with a plate AND grade 8 bolts your potentially in more danger than when you started. Don't skimp on mounting plates.
My 2 cents.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current)
past rides were:
'70 Chev 2wd farm truck
'71 GMC 2wd 1/2T 402 nice!
'72 Chev 2wd 1/2T 396
'72 GMC 3/4T 4x4 2500 Super Custom suburban.
Bozeman, Montana
mt Al is offline   Reply With Quote
Old 02-06-2003, 04:37 PM   #6
krazy_texan
krazy_texan's Avatar
can you put vinyl and cloth die on seatbelts i have an 87 burb in the driveway that we are parting out and i was thinking of using the seatbelts out of it if i can die them and paint the houseings black to match my truck
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-06-2003, 07:02 PM   #7
71Derelict
thanks for the help guys.
71 C/10 Short Wide
Old 02-07-2003, 11:23 AM   #8
oldcarbuff
I just bought some from truckandrv.com. They were new and snapped into the blazer seat I used. They were $35 each, but did not include mounting plates for under the floor.
I have also used ones from southern rods (cant' remember the web site). Lastly, I was looking real hard at the ones from http://www.andoauto.com/seat_belts.htm
I really like the aviator style flip up chrome latches.
OCB
oldcarbuff is offline   Reply With Quote
Old 02-07-2003, 11:55 AM   #9
Lippyp
English Chevy Owner
Lippyp's Avatar
Just a quick note of caution on buying second hand seat belts. I wouldn't recommend buying secondhand seat belts without knowing some history of the vehicle they came from. If they are late model belts it is quite likely that the vehicle has been in an accident. Seat belts can stretch and the stitchingcan be weakened if they are involved in a major accident when they restrain what may have become several thousand pounds owing to the decceleration forces involved. This could mean that if you have a major accident they could fail. In the UK most accident repairers after a head on impact will automatically replace the seat belts. If you do fit used belts at the very least renew the mounting hardware, bolts etc.
Its your face and your loved ones that could exit via the windshield if they fail, my truck has brand new UK spec three point belts fitted.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 02-07-2003, 05:10 PM   #10
Edmond
Edmond's Avatar
Were did you get these new seatbelts Lippyp??
Any pictures?
Thanks.
Cya,
Edmond
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb
1974 Chevy Camaro Z28 (Original)
The Netherlands
Edmond is offline   Reply With Quote
