Old 02-08-2003, 08:28 PM   #1
bubbastrick
Angry motor mounts
Hi folks:
I have a '69 Chevy C-10 SWB sitting in my backyard that my Dad has decided he wants to try to get going again. It does not have a motor in it, but it did have a V8 (which is now in my S-10). He has found a complete straight six he wants to buy, and I need to know the differences between the V8 and the 6 cylinder mounts. Is the piece that is mounted to the frame different, or the piece that mounts to the block? I have never had the opportunity to fiddle with a truck with and inline motor in it so any help would be appreciated.
Also would a TH350 that bolted to a smallblock also bolt to a straight six?
James Strickland
AS Computer Information Systems
“Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge”
~E.J. Potter
bubbastrick is offline   Reply With Quote
Old 02-08-2003, 08:53 PM   #2
Tim Christian
Tim Christian's Avatar
The frame towers are different. The motor mounts that bolt to the block are actually the same. The frame towers are longer and have a extra block that bolts to them they also mount in the two holes in the frame that are closer to the firewall and yes a 350 turbo will bolt up. I have all the 6-cylinder mounts if interested. Tim
Tim Christian is offline   Reply With Quote
