04-24-2010, 08:46 PM | #1 |
'70 C10 Burning Brakes
So it was nice and sunny today and my brake light came on Thurs so I decided to bleed the brakes. After I was finished the light was gone and I had a real firm peddle but when I took it for a drive it had a real bad burning brake smell and I could tell the truck was dragging. I swapped out the drums for discs last year and have driven it all winter with no problems. Any ideas?
04-24-2010, 09:02 PM | #2 |
Active Member
Re: '70 C10 Burning Brakes
Did you do discs all around? Also, did you replace all the rubber break hoses at the same time?
It sounds like a collapsed brake hose. They swell and collapse on the inside so you don't see it. That keeps the fluid from returning and locks the brakes. |
04-24-2010, 09:15 PM | #3 |
did you change out the master cyl and proportioning valve to do a proper conversion
04-24-2010, 09:27 PM | #4 |
Discs up front, drums in rear. Swapped everything from a '75. Booster, master cylinder, prop valve. I installed new rubber hoses during initial install. Everything seemed to be working fine until I bled the brakes today.
04-24-2010, 09:39 PM | #5 |
Grandpa in the rustmobile...
Same problem happened to me! I ended up having a wadded up rubber gromit between booster/MC. Check to see if your hoses are all tight and your MC is opening closing correctly, and check your linkage. Hope ya get it!!!!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-25-2010, 11:28 AM | #6 |
also check brake pedal that it isnt stuck down a bit and keeping brakes applied
