Old 05-05-2010, 02:36 PM   #1
BLT-NT-BOT
A/C question
I am putting my a/c duct hoses back in right now, and I saw a center vent plug kit available. Is it a benefit or not to having only one hose go to the center vent instead of two. I would be nice to get rid of one of the hoses for the room under the dash, but is it worth it.
BLT-NT-BOT is offline   Reply With Quote
Old 05-06-2010, 03:33 PM   #2
tqlspec
tqlspec's Avatar
Re: A/C question
I went with the one hose setup when I redid mine. The air flow is somewhat stronger out the center vent with this setup. I wish I could find a vent that was easier to close off like the side vents - it comes out so strong.
tqlspec is offline   Reply With Quote
Old 05-06-2010, 05:47 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: A/C question
I use the one hose set up in both of my trucks. Don't waste your money on the "kit" though, it is junk. Just get a couple rubber pipe caps from Home depot or Lowes for less than $5. Cap one end of the center vent, then cap the other end at the box where the hose came out of.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-06-2010, 09:06 PM   #4
71 super
71 super's Avatar
Re: A/C question
Also makes radio and othe movement under dash easier, the second hose always seems to be in the way...
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-06-2010, 09:08 PM   #5
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Re: A/C question
My thoughts exactly....
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 05-06-2010, 09:51 PM   #6
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: A/C question
I used 2 spray can plastic caps and some duc tape worked perfect
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-06-2010, 11:36 PM   #7
BLT-NT-BOT
Re: A/C question
Thanks guys I think ill get rid of one hose and clear some room.
Old 05-07-2010, 12:04 PM   #8
Tkmadone
Re: A/C question
Does anyone know of a replacement for that center das vent so you can direct the airflow better? I've always wished I could point that flow at myself instead of it just coming straight out...
Tkmadone is offline   Reply With Quote
