Old 05-08-2010, 09:10 PM   #1
aggieguy713
aggieguy713's Avatar
Possible timing issue?
Just recently replaced my cap and rotor buttonwith an accel super coil. For about the past week when I get into fourth or fifth gear and get on it, it backfires through the carb and then it will cut out and die. Just yesterday, I had to call a buddy of mine to pull me home because it was acting like it was flooding out and j couldn't get it to stay running. Not sure if this is a timing issue or a carb adjustment, thanks.
70 Chevy C10, LT1, T5, "Blue Beast"
aggieguy713 is offline   Reply With Quote
Old 05-08-2010, 09:17 PM   #2
LandonL
LandonL's Avatar
Re: Possible timing issue?
Does the truck not even want to start? If it has a hard time starting you may've loosened the nut holding the distributor down. If you can twist the distributor freely right now, all you need to do is tighten the bolt. Happened to me but I had to push it home haha.
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 05-08-2010, 09:20 PM   #3
aggieguy713
It starts, hut acts like it's not getting enough gas or the timing is too retarted. No the bolt is there. We had a friend of mine get the timing pretty close not sure what to do at this point.
Old 05-09-2010, 11:10 AM   #4
LandonL
LandonL's Avatar
Is it not getting enough gas?
250 L6 .030 over
Old 05-09-2010, 11:29 AM   #5
cdowns
cdowns's Avatar
i'd recheck what you did// like the sparkplug wires and make sure they r wired right going to the proper cylinders
Old 05-09-2010, 12:13 PM   #6
junkyardjohn
junkyardjohn's Avatar
EXACTLY... IF IT WAS RUNNING GOOD B-4 YOU DID THIS, & NOW IT'S NOT... WELL I'M NOT A BIG BELIEVER IN COINCIDENCES. (MORE THAN LIKELY SOMETHING YOU DID OR DIDN'T DO) JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-10-2010, 09:14 PM   #7
aggieguy713
All the sparkplug wires are right, the timing is as close as i can get it without having a timing light. It was backfiring before the change, just got progressively worse (maybe a coincidence). Question is now...how do i begin to tune the carb?
Old 05-11-2010, 08:12 AM   #8
neba
usually when it backfires thru carb its too lean, not enough fuel. i would check fuel filter, then fuel pump
neba is offline   Reply With Quote
Old 05-11-2010, 09:01 AM   #9
68gmsee
Active Member
68gmsee's Avatar
It is possible for the timing to do this but if it starts okay after sitting a while and then acts up, something else is causing you problem.
I'd look inside the carb throat with a flashlight immediately when it acts see if you can smell or see fuel dripping into manifold. If you have a quadrajet, they're known to have leaking problems and need to be epoxied.
Don't overlook the possibility of bad valves. Escaping hot gasses will prematurely ignite fuel in the intake and cause it to backfire up the carb.
My vote goes for the overly rich/flooding condition, though.
68gmsee is offline   Reply With Quote
Old 05-11-2010, 10:34 AM   #10
norske
Had this happen to me and the pickup coil in the distributor was bad. Checked it with an ohm meter, it read 900 ohms, should've been open.
norske is offline   Reply With Quote
Old 05-11-2010, 04:26 PM   #11
kcjones
I wish I was a cowboy
kcjones's Avatar
You need to time it with a light if at all possible. If it's too retarded or advanced, yes, it will cause backfiring, especially if there is also some carb tuning needed. How did you time it without a light?
To answer your carb question, basic carb tuning probably isn't going to help with the problem you're having - full throttle acceleration at low rpm/heavy load (I assume this is what you mean - get into 4th or 5th gear, step on it...). Generally, if you're having problems immediately upon dropping your foot, it's in the accelerator pump system: cam, lever, pump diagram, pump nozzle. If it runs ok if you feather the throttle a little, maybe it is running lean at heavy loads...in this case, maybe your secondaries are opening too early? What type of carb? Is the backfiring at a specific rpm? Maybe since you changed your coil to a stronger coil, there are other things in the ignition system to look at? Wires, plugs, plug gaps...
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 05-12-2010, 07:02 AM   #12
dwaite72lnghrn
First what kind of dizzy and other addons do you have?
My first thought would be the mechanical weights have rusted and stuck open when you timed it first then loosened up after running now your timing is way off.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
