Old 05-20-2010, 11:17 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Question about RPO Code on Spid
I have no Spid in my truck so I contacted GM and received the package with the codes and info from when it was built. I understand all the codes except one and it shows "Z32 Rear Wheel Equip". Does anone know what that code means?
I thought it might have something to do with the spare tire and wheel but they are coded seperate as "Z33 Spare Wheel Equip" and "Z34 Spare Tire Equip"
Another question I have is that the original engine code for my truck is LS9 the 350 engine and M38 3 speed auto trans and no posi. With that combo it shows I should have the 3:73 as the standard ratio rear end with the 3:07 and 4:11 being optional. I have the 12 bolt in my truck so I am assuming I have the standard 3:73 because they'd put a 10 bolt with the 3:07 wouldn't they?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-20-2010, 06:26 PM   #2
Already Gone
Re: Question about RPO Code on Spid
ttt
Old 05-20-2010, 07:25 PM   #3
71 super
71 super's Avatar
m49 was the option code for automatic, 350 or 400- if the code had a * following the m49 (m49*) I beleve it designated the 400, but both transmissions carried the same option number. m38 is the code for a standard shift three speed
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-20-2010, 07:29 PM   #4
68350
68350's Avatar
3.08(3.07) gears are standard with the TH350.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 05-20-2010, 08:23 PM   #5
LONGHAIR
I don't know for sure on these older trucks, but in the '73-'87 generation you could actually get the "spare wheel" w/o a tire mounted. I have seen lots of them in the dealerships with a bare wheel in the undermount carrier.
I don't really know what the point of that was?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-20-2010, 09:58 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
some trucks actually did get the car deignation of M38 for the TH350, either way, the 3.07 gear was standard with the TH 350 or TH 400 in a 1/2 ton 2 wheel drive.
Also, in 1/2 tons, there were no 10 bolt rears.
Old 05-23-2010, 12:07 PM   #7
Already Gone
Yes I agree with you. I would think that is the case except I also have Z33 Spare wheel Code and Z34 Spare tire Code.
Old 05-23-2010, 12:13 PM   #8
Already Gone
My truck was redone by someone long before I got it in 2001. I didnt know all the trucks came with 12 bolts and that is good to know. I think I have 3:73 gears because of the RPMS ( from a factory added tach ) at highwat speeds and the terible gas mileage. One of these days I guess I should pull the cover off the rearend and find out for sure. The truck also has a TH400 now instead of the original 350trans.
Old 05-23-2010, 01:01 PM   #9
Longhorn Man
on the MPG... it's tough to get good numbers. on a poll I did on here, the majority of us are getting 10 - 12 MPG.
What kind of RPMs you turning @ 60 MPH? 2300 - 2500 (the variables are converter slippage and tire size) would indicate a 3.07 gear.
Old 05-23-2010, 01:50 PM   #10
Already Gone
I'm running 235/70R15's on the truck and it is doing 3000/3100 RPM's at 65 MPH and yes I get 12 mpg on the highway and 10 in the city.
Old 05-23-2010, 03:03 PM   #11
48richard
48richard's Avatar
I also have no SPID - who did you contact to get your truck information?
Richard
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 05-23-2010, 03:41 PM   #12
Already Gone
Richard
I contacted GM in Canada. I do not know if you guys in the USA can get the same info. Below is the email address of the guy I contacted to get the info,he may be able to steer you to the right person for the USA info.
george.zapora@cc.gmccanada.com
Old 05-23-2010, 08:09 PM   #13
Longhorn Man
GM didn't keep that info on US trucks, only GM of canada did
Old 05-24-2010, 11:13 AM   #14
48richard
48richard's Avatar
Too bad, but thanks anyway.
Richard
