05-22-2010, 11:37 AM | #1 |
Can you smell that??
Need a little help with the smell of gas in the cab. When I fill the tank up to more than 3/4 full the fumes are terrible in the cab. Is there a vent issue that I need to check or is this normal?
I usually avoid it by only putting enough gas in to half or a little more. |
05-22-2010, 11:53 AM | #2 |
Re: Can you smell that??
Mine smells too but it is the same with 1/2 or 3/4 of a tank. Maybe you have a leak somewhere up higher in the tank?
05-22-2010, 02:30 PM | #3 |
do we need to guess the year?? if so is there a prize?
05-22-2010, 02:49 PM | #4 |
20' Daredevil (Ret)
Assume you are talking about the tank behind the seat. It could be as simple as replacing the gas cap. When the seal goes bad, you can get gas smell -- worse with more fuel in the tank, worse with the window down, worse on right-hand turns....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 05-22-2010 at 02:50 PM. |
05-22-2010, 02:50 PM | #5 |
Sorry. 1968 GMC behind the seat
05-22-2010, 03:04 PM | #6 |
also another is the sending unit// the rubber oring gasket between the sending unit and tank dryrots and will leak fumes and liquid
05-22-2010, 06:38 PM | #7 |
Cruzin
i agree with the gas cap been there
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
05-22-2010, 06:51 PM | #8 |
X3 on the gas cap. Been there more than once.
05-22-2010, 06:56 PM | #9 |
Moderator
Check the gas cap, also check the filler neck. A lot of times that is cracked from years of pushing/pulling/resting the gas filler on it at the station.
I would also check the sending unit gasket and the rubber lines that connect the sending unit to the hard lines.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-22-2010, 08:58 PM | #10 |
also check the vent lines. some of them run up and over the back window in the cab. still cannot believe GM did that x4 on the gas cap also . cheers, Pat
05-23-2010, 12:11 AM | #11 |
X4 on the "vented style" gas cap. Previous non-vented cap = a gas buzz.
"Do not follow where the path may lead. Go instead where there is no path and leave a trail." "SEMPER FI" Never retired-Always a Marine '72 C10 Longhorn-very daily '86 C10 Van (mothballed) previous; '65 C10 shorty & bunches of M/C's |
05-24-2010, 04:39 PM | #12 |
Bought the new gas cap, filled her up and viola!!!! Thanks for the help!!! I love my truck more and more everyday!
05-24-2010, 07:57 PM | #13 |
just blame it on the dog. I do
1967custom |
05-24-2010, 08:08 PM | #14 |
Factory Strippers Rule!
Yeah, I sometimes smell gas in my truck... and it's not liquid form, usually.
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
05-24-2010, 08:47 PM | #15 |
Big Red - Now its a SWB!
I have that problem too, but its usually when I have my dog or my father-in-law riding with me .
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
05-24-2010, 09:28 PM | #16 |
So wheres the best place to get a replacement gas cap? because I have the same problem, and my wife wont go anywhere with me in it because of the smell.
05-24-2010, 09:53 PM | #17 |
20' Daredevil (Ret)
Got mine at Napa.
05-25-2010, 12:10 AM | #18 |
got mine at kragens, any autoparts place will have them.
