05-31-2010, 09:44 PM | #1 |
Brake issues
I am have a issue with soft pedal in my project. Replaced entire brake system except for rear brake hose. New disc/drum setup with manual m/c with prop valve. Bench bled m/c, gravity bled system 2x did the pump and hold 2x went through 3 bottles of fluid but still have soft pedal. BUT if i pump it up quicky and dont release the brake pedal completely it stays firm. Just keeping the pedal pushed down 1/4 inch keeps the brakes up. Could there still be air in the lines or do you think there is other problems?
06-03-2010, 04:37 PM | #2 |
Cantankerous Geezer
Re: Brake issues
A couple of possibilities.
Check the rear hose. Does it expand when pressure is applied? Check all connections for leaks. When bleeding, I use a clear hose and bottle. Loop the hose so it is above the brake cylinder or caliper. When the pedal is depressed, you should not have any bubbles in the fluid in the hose. If their are and only on one wheel, there is a leak at a fitting for that wheel. If there are bubbles at all wheels, the problem is with the master cylinder. If bubbles at only front or rears, a leak between the m/c and the tee for that set.
Fred There is no such thing as too much cam...just not enough engine. |
06-03-2010, 05:42 PM | #3 | |
Re: Brake issues
I went ahead and replaced the hose just in case it was a issue. Still soft pedal. I removed the lines coming out of the m/c and plugged them to do a pressure test on m/c and its fine. I am using the clear hose /bottle but i am not looping the hose above the wheel i am bleeding so i will try that. When i am bleeding i do not see any air bubbles and I do not see any leaks anywhere? Very frustraing!! I think i will clamp off the rubber hoses and try to isolate the problem area ie.front/back. If you have any other ideas let em rip!! thanks again |
06-03-2010, 06:59 PM | #4 |
Re: Brake issues
Sorry to ask the obvious, but nobody else did. Are the calipers installed so the bleeder screws are at the very top? They do have a left and right. Some rear wheel cylinders also have a left and right but it is harder to install those upside down.
Ray |
06-03-2010, 07:04 PM | #5 |
Re: Brake issues
Thanks for the reply, They are pointing up but not completely at 12:00. I did remove them and turn them as i was bleeding the system to ensure all air was out of them. It really feels like air is still in the system but after bellding so many times i find it inprobable but not impossible! Thanks again!!
06-03-2010, 07:45 PM | #6 |
Re: Brake issues
could be the metering valve, you sometimes have to push or pull the pin when bleeding the brakes. air is probly being held back by it.
06-03-2010, 08:29 PM | #7 |
BMW & ASE Master Certified
Re: Brake issues
So, this project truck, does it feel soft compared to before you started messing with the brakes? Was it power brakes before you messed with it? whats your project? are you comparing the pedal of yours to something else? if you have all of the air out, maybe your M/C is incorrectly sized to the application.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
06-03-2010, 09:07 PM | #8 | ||
Re: Brake issues
When i got the truck it was in boxes so i really dont know how they were before i got it. As for the comparision i really dont have any thing except power brakes but they are really soft and go to the floor. I bought a m/c kit from Performance online specifically for my setup so that should be ok too. I pinched off all the rubber lines and opened 1 at a time and it appears the problem is in the front brakes. When i pinch off both front lines and leave the back open the pedal is high and hard. pinch off rear and pedal is low and soft. I dont know where to go from here. Thanks again for all the suggestions Mark |
06-03-2010, 11:52 PM | #9 |
Re: Brake issues
Explain your bleeding procedure (how do you manipulate the pedal; what are you bleeding 1st, 2nd, 3rd, 4th; etc). Maybe it's something there??
06-04-2010, 12:20 AM | #10 |
Re: Brake issues
[QUOTE=SCOTI;4013060]Explain your bleeding procedure (how do you manipulate the pedal; what are you bleeding 1st, 2nd, 3rd, 4th; etc). Maybe it's something there??[/QUOTE
Thanks for the reply, For both gravity and the "pump,hold,bleed" method i start from the p/s rear, d/s rear, p/s front, d/s front. I use a length of clear tubing into a clear bottle 1/2 full of new fluid. The hose is submerged into the fluid. For the gravity method I just open a bleeder and let run until the m/c is 1/2 to 3/4 empty and repeat pn all wheels. The other method we pump brakes until they start to feel firm, hold pedal, open bleeder until the pedal goes almost to the floor. lather,rinse,repeat! Does this sound ok? I have a feeling the problem is something really simple or really stupid (probably both!) that i messed up! |
06-04-2010, 12:44 AM | #11 | |
Re: Brake issues
Try starting w/o pressure on the pedal. Leave the pedal unpressed. Open the bleeder screw & then slowly (not slow-motion, but not panic stop either) depress the pedal until it bottoms out. Hold the pedal bottomed out until the bleeder screw is closed. Release the pedal slowly. Repeat. I do this x3 @ each corner (farthest from master cylinder to closest like you're doing). It seems to help the prop valve 'sticking' issues. See if that does anything for the issue.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-04-2010 at 12:45 AM. |
06-04-2010, 09:39 PM | #12 | |
Re: Brake issues
06-11-2010, 08:13 PM | #13 |
Re: Brake issues
Well, I worked on the brakes again and now i have a semi firm pedal about 1/2 way through the distance of the pedal but if i push really hard i can get it to the floor. I also noticed that the front pads move way before the rear shoes start to move. could this be an issue with the residual valve? I called the place where i bought the kit and they said no. Any ideas?
06-12-2010, 04:04 PM | #14 |
vw guy & now c-10 guy
Re: Brake issues
i just redid all of my brake system and upgraded to front disks and power brakes while i was at it and I was having a little trouble getting mine to bleed as well. I dont know if you said this but make sure you bleed between the master and proportioning valve- I had some air there
06-12-2010, 04:56 PM | #15 |
Re: Brake issues
when you bleed the rears you should bleed the furhest away first which is the drivers side then the passenger side second
also the rear brake shoes should b out very close to the drums,less than a thousandths of inch thats the way to do it on the 67-72chevy trucks which is a guess since no brand or year was mentioned
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 06-12-2010 at 06:30 PM. |
06-12-2010, 08:20 PM | #16 | |
Re: Brake issues
As many times as ibleeded the brakes i cant think there is still air in the lines but i might break down and buy a pressure bleeder to be sure. I still think its odd that the front brakes react way before the rears???? |
06-14-2010, 02:53 AM | #17 |
Re: Brake issues
06-14-2010, 07:46 PM | #18 |
Re: Brake issues
Thanks for the reply. Glad to hear thats a normal issue. I still need to figure out why i dont get any real pedal until about 1/2 way through the brake pedal stroke? Any ideas on that?
