Old 07-30-2010, 06:17 PM   #1
lytemup454
lytemup454's Avatar
big block help
Hey guys I need some help, a friend of mine just got a blazer w/ a bb. It isn't installed yet and he's wondering what it is going to take to get it in there. I don't spend a lot of time in this forum so I figured I would ask the experts.
Thanks Ian
lytemup454 is offline   Reply With Quote
Old 07-31-2010, 12:02 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: big block help
Here's a great thread for you to check out.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-31-2010, 01:35 AM   #3
lytemup454
lytemup454's Avatar
Re: big block help
Thanks Yukon that helps a lot!
Old 07-31-2010, 07:49 PM   #4
turp mcspray
turp mcspray's Avatar
Re: big block help
If you change the transmission at the same time for a longer one, such as a 400 instead of a 350, you can move the engine forward. This will prevent having to modify the firewall, which is a lot more work as Yukon can tell you. If you add a longer trans, you can also leave the transfercase and transmission mount in the stock location, eliminating having to relocate more stuff and having to modify your driveshafts. Do a lot of research before hand, so you can decide what route you want to take, as far as modifications go. Go luck on your big block swap!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-01-2010, 12:19 PM   #5
Long Roof
Old School, New Style
Long Roof's Avatar
Re: big block help
700r4 transmissions are also longer and you get 4 gears. If it were me I would leave the transfer case in stock location, use a 700 tranny, move the engine forward and put a spring lift on so the oil pan clears the front axle.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
