Old 08-22-2010, 09:28 PM   #1
Papaloo
Papaloo's Avatar
2004R and column shift detents
So I have a LWB 1972 Custom Delux C10 with a 350 engine and worn out th350. A friend that does cross country races with junk cars offered me a th350 he had sitting in his shed that worked when he pulled it. Well, I got there and I look at it, and it's not a th350, it's a 2004r from a early 80's Monte Carlo SS. It even had a mechanical speedo out. I was pretty excited because I knew that was pretty much a direct swap for my th350, but for all my searching on here, I have one question I haven't been able to answer. I've never dissasembled an automatic column before so I don't know how the column shift mechanism and detents are setup and work. Do I need to change anything in the column for the 2004R? If I don't change anything in the column, is D the overdrive and then L2 and L1 are 3rd and 2nd gear with no way of manually shifting the tranny into first? Hope this makes sense
Dave
1971 Chevy K10
1972 Chevy C10
Papaloo is offline   Reply With Quote
Old 08-22-2010, 09:58 PM   #2
jay6891
Car Knocker
jay6891's Avatar
Re: 2004R and column shift detents
You hit it on the head. No need to change anything in column. Like you said, d is now overdrive, and so on. I can hit low on my 700r4 but my column is a little wore out.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 08-22-2010, 10:55 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
...with a different linkage, and the 4sp auto indicator for the column...would it work properly then, allowing access to all the gears?
I'm probably going with a floor shifter but just wondering...
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
