Old 09-19-2010, 02:08 PM   #1
Jon M
Installing Early Classic Sway Bar
Hello everyone,
I am installing an ECE sway bar and having some difficulty. I am wondering if there is a "left and right" to the sway bar and if I have have it in upside down. The "U" clamp that holds the bushing to the lower control arm seems to be a long way from the control arm, and at a severe angle. I had to put a c-clamp on it to draw it down so I could get the bolts in. When I tighten up the bolts the bushing is popping out from under the "U" clamp becuase of the angle of the way bar is so different than the surface of the control arm. Anybody have experience or a picture to post? The ECE instuctions aren't very good.
Thanks!
Jon M is offline   Reply With Quote
Old 09-19-2010, 02:27 PM   #2
jay6891
Car Knocker
jay6891's Avatar
Re: Installing Early Classic Sway Bar
Here are some pics. Not same year model but basically same.
http://67-72chevytrucks.com/vboard/s....php?p=3394348
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-19-2010, 08:45 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Hey Jon.
While there's not really a left or right side to the bar, there is a right and wrong way for it to be mounted.
The front of the bar, after being mounted in the a-arm bushings, should kick up.
If your bar is kicking down after being mounted in the a-arm bushings, pull it, flip it and reinstall it.
Sorry I don't have pics for assistance, but check you bar and I think this should help you out.
Cheers!
Nate
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-13-2014, 04:31 PM   #4
that_ry_guy
Hey everyone,
Just finished the ECE drop sway bar installation. Not 100% sure if I got it the right way or upside down. Seems to fit a bit weird both ways, likely because there is no weight on the frame. Won't torque the bolts down until engine in place. The bar does seem to "kick up" after the control arm. Do you guys think I got it right? Thanks
that_ry_guy is offline   Reply With Quote
