Old 09-19-2010, 08:23 PM   #1
Leon E Morris
tilt steering wheel help
I picked up a tilt steering column for my 67 yesterday at a swapmeet but it is shorter than the origonal column is there mods i need to do to make it fit in my truck?
Leon E Morris is offline   Reply With Quote
Old 09-19-2010, 08:40 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: tilt steering wheel help
Hey Leon,
Sounds like you picked up a van tilt.....thus you may have to relocate the Neutral Safety switch at the bottom of the column....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 09-19-2010, 09:06 PM   #3
Leon E Morris
it doesnt look like it has a collapsable shaft on it like the orig one does or is it already collapsed?
Old 09-20-2010, 05:54 AM   #4
JimKshortstep4x4
Does your 67 have the original column with the very long shaft? If it does then the Van Tilt will work if you get the later shaft extension (69-72) which is the collapsable part.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-21-2010, 08:04 PM   #5
Leon E Morris
how hard is it to change the shafts in those columns i do have the collapsable one?
Old 09-21-2010, 10:21 PM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Its easy. Just unbolt the rag joint at the power steering gear and the clamp at the end of the steering column. Drill out the plastic rivets in the newer style end and install!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
