Old 09-25-2010, 11:20 PM   #1
weekendracer728
weekendracer728's Avatar
Exhaust on slammed trucks
What are you guys running for exhaust on frame layying trucks?? I want to run true duals all the way to the back bumper with the frame on the ground. Does anyone have this setup now??
weekendracer728 is offline   Reply With Quote
Old 09-26-2010, 12:32 AM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Exhaust on slammed trucks
it can be done, but you will need to:
1. make sure your headers, if your running them, tuck below the frame,
2. route the exhaust through the crossmember
3. running the pipes very close to the bed floor when you loop over the rear axle, or
4. run the exhaust OUTBOARD of the fram rails. seen it done on older rigs....
with careful planning, it can be done!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 09-26-2010, 01:51 AM   #3
nastyc10
nastyc10's Avatar
I'm running shorty headers with the pipes tucked up in the frame rails through the early classic rear crossmember and dumped before the axle. A raised bed floor would give you more room out back.
nastyc10 is offline   Reply With Quote
Old 09-26-2010, 02:34 PM   #4
weekendracer728
I plan on running a twin turbo sbc, so headers should not be a problem
Old 09-26-2010, 02:36 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
What type of rear suspension are you going to run? That will determine how hard it is to get the exhaust all the way to the rear.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-26-2010, 03:22 PM   #6
YBNORML
YBNORML's Avatar
Has anyone run a full exhaust with a rear dropmember?
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 09-26-2010, 04:14 PM   #7
muthstryker
muthstryker's Avatar
Ya I would use shorty headers as well, they will beable to tuck the exhaust up better. Also I, myself am going to have a new trans crossmember made so I can run a true dual exahust. There isnt alot of room to do so with the stock one. The New crossmember should provide almost 2.5-3"s more clearance for the exhaust and be a hell of alot stronger.
muthstryker is offline   Reply With Quote
Old 09-29-2010, 02:16 PM   #8
weekendracer728
ttt
Old 09-30-2010, 01:04 PM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-30-2010, 01:08 PM   #10
weekendracer728
Originally Posted by smashingchuck View Post
That is right, you have it in your build thread-thanks!!
